Forced Induction Using An Auto Gear Box?
10 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 16 December 2019 - 07:02 PM
Just wondered if an autobox can handle super charged set up.
#2 DeadSquare
DeadSquare
  • 3,120 posts
Posted 16 December 2019 - 08:05 PM
I looked at putting my Shorrock on a 998, but getting the 'throttle lift' for gear changes seemed too much bother.
#3 REDICE
REDICE
  • 99 posts
Posted 19 December 2019 - 08:09 AM
Y
#4 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 20 December 2019 - 02:01 PM
Can you ever trust a random person online who'll say a certain component will take xyz power and no more.
Try it and see, it's only an auto box afterall.
#5 mini13
mini13
  • 3,810 posts
Posted 20 December 2019 - 06:13 PM
I've heard of tuned autos before but nothing over about 110 hp, I belive the main issue us the brake bands have an upper torque limit, I think at one point Mra minis were doing some uprated ones, no idea what they could take though.
I would expect if you tried it you'd have to become an auto box expert fairly quickly.
#6 Ethel
  • 25,980 posts
Posted 21 December 2019 - 12:09 AM
I would imagine it's not that different to a manual box in that it'll fair better with sympathetic driving. Maybe shift manually and lay off the go pedal until it's engaged the gear. Torque will be the killer so modulating the boost at peak torque rpm could improve what power you can get without toasting the clutches.
I believe the boxes vary too with stronger ones under 1275's?
#7 DeadSquare
DeadSquare
  • 3,120 posts
Posted 21 December 2019 - 09:59 AM
It was quite long time ago, but I have pulled apart several auto boxes, and I don't remember noticing any difference between 1000 and 1300 ones.
As for taking more power, I had no problems when I ran a 731 under an 1100, with the governor suitably adjusted to change at about 6,000RPM.
As I mentioned above, because the carb moves to the end of the supercharger, it is no longer aligned with the governor control rod;  this either means introducing a cable, but the cable would have to push as well as pull, or bell cranks, and at the time, I was too busy to build the linkage.
#8 nicklouse
  • 18,618 posts
Posted 21 December 2019 - 02:04 PM
Yes. How far? drop guessworks a message and ask.
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 21 December 2019 - 09:59 PM
to be honest there's a few people's opinions I trust on here. Me asking the question like this saves me having to message each one directly and the answers can provide a reference for others in the future. So not as 'random' as you would like to assume, but thanks for your input.
Edited by HUBBA.HUBBA, 21 December 2019 - 10:03 PM.
#10 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
already have
#11 AP2020
AP2020
  • 89 posts
Posted 21 January 2020 - 11:33 AM
Turbo is easier as you can get the kick down linkage past the turbo / manifold etc. Its down to cost, the parts that fail are the bevel gears as the friction plates and bands can be uprated 0.3 to 0.6mu friction thus effectively doubling the torque, but the bevels cannot be uprated .
Clutches of any type rely on the following basic equation.
RxNxFxP
R = mean radius
N = number of surfaces, ie one friction and one reaction face is counted as 1, a conventional mini clutch is 2 faces
F = Friction coefficient
P = Pressure
Sil metric units
