Mpi Fuel Filter ?
6 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 17 December 2019 - 06:45 PM
Hi chaps back again,
Hi I'm after a fuel filter, fuel filter to tank pipe and fuel filter to engine pipe for a 1997 mpi mini chassis number WD157647 I’ve contacted Minispares and they responded with this
the only part numbers we can do are GFE7059, WKB10018, WKB10019 and EDP9976 x2. The main fuel line is not available.
Unfortunately I need the main line aswell, is there another way to set this up on my car maybe using the later filter and associated parts ?
#2 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 18 December 2019 - 07:03 AM
Hi
if you want a main fuel line from tank to engine the 3 lines you mean
i found in ebay a used one
also you can buy the brake line by meter and make new lines
why you want to change the fuel line?
#3 leepol83
leepol83
  • 1,744 posts
Posted 18 December 2019 - 09:00 AM
Hi I’m not changing the 3x fuel lines it’s the one before the fuel pump (a bend with rubber bit) and the other one is off the pump into the boot (funny shape pipe with adapter)
#4 leepol83
leepol83
  • 1,744 posts
Posted 18 December 2019 - 09:38 AM
Had a look on Minispares do you think I could convert to the later type filter and associated pipework ?
#5 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 19 December 2019 - 04:55 AM
Hi
i got your point
i changed my fuel pipe before and only found it in somerford mini under parts no: WJP105860
http://www.somerford...KtE4-Od6RtJXbK2
and they have a full kit with filter for the two mpi model with adapter and without
note: some filter need to fix the adapter and some filter no need to put the adapter for filter
hope this what you are looking for :)
Edited by Kubbar, 19 December 2019 - 10:19 AM.
#6 leepol83
leepol83
  • 1,744 posts
Posted 19 December 2019 - 07:39 AM
Thanks kubbar that’s brilliant thanks so much ?? Exactly what I’m after top guy thanks again
Lee
#7 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 19 December 2019 - 10:20 AM
Thanks kubbar that’s brilliant thanks so much Exactly what I’m after top guy thanks again
Lee
you are most welcome  :)
