judering problem when coming down
39 replies to this topic
#1 Matt
Matt
  • 4,703 posts
  • Local Club: The mini forum - i live here
Posted 24 October 2006 - 11:22 AM
Hey guys...
Kattypillas car is having some problems...
its recently started juddering when coming down from the revs.. and when accelerating (only slight juddering) until 3500rpm.
i thought it was because she had put C**p fuel in tank.. so i filled it up with bp optimax.. and ran it around for half an hour.. still not much better.. decided redex in the tank and some on the filter would make a different... yeh it did... very much so.. it make the car quicker but still juddered. lol.
kinda running out of ideas here.... any ideas...
she also tells me the other night she was driving and she heard what sounded like lots of stones being chucked at the car from the front of the car?
but then it stopped... so she cranked up the stereo and thought she heard it again so turned it down.. and she hasnt driven the car again...
its not the gearbox going is it??
quick spec of car
1275... mini 35..
seems standard other than hiff35 carb and k+n cone filter.
electronic ignition...
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 October 2006 - 11:26 AM
HIF35... was there ever an HIF35 carb built? i think you mean HIF38.
funny problem mate i'm not sreally sure what to suggest other than check for anything clearly loose in the engine abay etc.
#3 Matt
Matt
  • 4,703 posts
Posted 24 October 2006 - 11:31 AM
not had half a chance to look at it yet.. some peeps might know what carb she has.. i think i rememebr her tell me it was that...
hmmm might just check all hoses and things..
when i took it out though.. it was running so well... but still juddering going up and down through the revs
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 24 October 2006 - 11:36 AM
Have you done any modifications to the engine etc??? Juddering is usually either fuelling or timing.... that's me being optimistic mate lol.
#5 Matt
Matt
  • 4,703 posts
Posted 24 October 2006 - 11:43 AM
nope only mod made to the engine was the carb as i say.. apparently its a hif 44 :S
#6 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 24 October 2006 - 07:17 PM
sounds like a plug has burned out or a lead dropped or even a blown head gasket between middle 2 cylinders!!
#7 topcat
topcat
  • 276 posts
  • Local Club: Six-Ex Mini Owners Club
Posted 24 October 2006 - 10:55 PM
I suffered from juddering for a long time. The engine mounts were partly to blame. It helped a bit by fitting a solid throttle disc because I has had the later type disc with an emmissions bypass valve. But the real cause of the juddering was the verto clutch disc. The springs had become really loose on the clutch plate. All depends on what sort of juddering you are talking about. Few things to ponder on though!
#8 TOMMO0302
TOMMO0302
  • 1,688 posts
Posted 25 October 2006 - 10:39 AM
TALK TO FRANK!
#9 dan__wright
dan__wright
  • 322 posts
Posted 25 October 2006 - 11:15 AM
its a hif 44, has a minisport inlet manifold, lcb exhaust and decat.
its got major issues, weve tried to get it setup before and just wouldnt run right, its possibly a problem with the valves.
Edit: also, its not the gasket or at least it wasnt before, did a compression test and all cylinders were fine.
Edited by dan__wright, 25 October 2006 - 11:22 AM.
#10 Matt
Matt
  • 4,703 posts
Posted 25 October 2006 - 12:15 PM
cheers Dan...
didnt think it was the gasket... couldnt pick up a leek on any of the cylinders, and compression test ran right too. so your right there :genius:
see its hard to be able to do anything to her car without knowing what mods are already on it.
timing is out by about 2 degrees... and the carb is running too rich... so its being overfueled.
pancake filter is clogged... so i have a fair amount of work ahead of me.
well if need be.. i have a stage 3 head, could put that on and change the carb. carb seems to be full of muck anyways. and the head is covered in spray paint... not house paint.
so might polish and port the orig.
#11 Jammy
Jammy
  • 25,397 posts
Posted 25 October 2006 - 12:45 PM
I would say, due to the fact that its fine after 3.5k rpm, that its probably something wrong with the top end, as Dan says, maybe a valve, or something slightly bent with the rockers? These are just educated guesses really, hopefully someone with a bit more experience will be along soon?
#12 Matt
Matt
  • 4,703 posts
Posted 25 October 2006 - 12:57 PM
well in which case i should just change the head... well kat can make the decision.....
#13 dan__wright
dan__wright
  • 322 posts
Posted 25 October 2006 - 01:36 PM
yup the tuning is way off, needle is wrong too, this is the only way it would run, get the timing correct or fueling correct and it wouldnt run, i thaught i was valve clearences but they were fine, never got any further.
why change the carb? hif44 is goof for 100BHP, just needs a cleanup and service, not sure about all of the gunk, it was cleaned when we put it on last year.
Edited by dan__wright, 25 October 2006 - 01:37 PM.
#14 Jammy
Jammy
  • 25,397 posts
Posted 25 October 2006 - 02:27 PM
Well going on what Dan says I would have the car rolling roaded first. A mini friendly rolling road should be able to diagnose any other problems with the car.
When Dan took his mini to MLM they were able to tell him he had a crack between certain valves in his cylinder head.
#15 Matt
Matt
  • 4,703 posts
Posted 25 October 2006 - 08:10 PM
knew the needle was prob wrong...
why change the carb? possible i might have my hands on twin carb with trumpets.
as jammy said it might be worth taking to be rolling road'd ive got a mate who can do it for me.
see if i can get him to have a look.
also think there may be too much compression which is another sign that the timing is slightly out... its almost like it struggles to start.
Ill eventually sort it out, even if i have to stick another engine in it. I will have this bloody thing working :genius:
that is if kat will let me do anything to her beloved car.... she might have objections if i take it to peices in our garage.
