New Throttle Body Mpi
4 replies to this topic
#1 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 20 December 2019 - 11:11 AM
Hi
I had problem with the old throttle body in MPI , sometimes hanging the RPM and not going back and I have to push the pedal to go down (when the engine hot) the issue with the butterfly rub the plastic, I changed the TPS and the accelerator cable is same issue.
At the end the issue was with the same throttle and I found the genuine one last piece and fix it in my car and now is perfect :) I know the SU company develop the throttle body and now is metal but I prefer to keep car original
the topic to share my story with the throttle :)
Regards,
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 24 December 2019 - 10:04 PM
The plastic throttle bodies distort due to heat and also can split. Hence the change. Seems like you have the former.
FS
#3 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 25 December 2019 - 07:00 AM
Dear FlyScot
I have a metal throttle body from SU, but it need some adjust. so I took the genuine plastic and no need to adjust the screw I think it adjusted by the factory. ( Also want to read the information from ACR4 for the throttle position for the future )
I think rover 200/25/400/45 have same body throttle (48 mm) in mini MPI, it just need to change the plastic accelerator bracket on it with your old mini bracket throttle body
here are the photo for it
Attached File  IMG_5243.jpg   32.37K   4 downloads
Attached File  IMG_5244.jpg   33.49K   0 downloads
Attached File  IMG_5245.jpg   33.07K   1 downloads
FS
#4 tmsmini
tmsmini
  • 744 posts
  • Local Club: MOASF
Posted 28 December 2019 - 04:12 PM
I have replaced the original TB with both 48 mm and 52 mm Burlen metal throttle bodies and have not needed any adjustment of the throttle stop on the TB. I did not think you could even buy the original plastic TB new any longer.
Terry
#5 Kubbar
Kubbar
  • Just Joined
  • 82 posts
Posted 31 December 2019 - 05:11 AM
Terry
Dear
you are right the TB no longer available in the net just the used one and I don't advice to take the used one.
as you can see I share the TB for rover 45 and you can change the bracket with Mini TB bracket and work good :)
