Can't Shift Into Gear
Best Answer Spider , 21 December 2019 - 06:28 AM
Clutch might just need adjusting.
Go to the full post
18 replies to this topic
#1 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 21 December 2019 - 01:16 AM
Hi Everyone,
My 62 Austin Mini has a new problem.  When I'm at a standstill, it's almost impossible to slot it into gear.  When I'm finally able to do so, it grinds the gears.
The problem came out of no where yesterday while at an intersection.
I'm able to shift between gears without it grinding, but it takes some extra force to get it into the new gear.
My mechanical skills are new .. I don't know where to start on this issue, so any help or advice is much appreciated!
Thanks,
Ryan
Edited by ryanlogsdon, 21 December 2019 - 01:29 AM.
#2 phillrulz
phillrulz
  • 617 posts
Posted 21 December 2019 - 01:38 AM
Clutch not fully traveling? When you start it in gear handbrake off does the car lurch forward? ( press the clutch )
Im guessing the car will move when you try start it with handbrake off and the clutch down.
Edited by phillrulz, 21 December 2019 - 01:59 AM.
#3 phillrulz
phillrulz
  • 617 posts
Posted 21 December 2019 - 01:41 AM
Hi Everyone,
Thanks,
Ryan
Also, ryan click the follow topic top right that way you get a notification when someone responds
#4 Spider
  • 14,867 posts
Posted 21 December 2019 - 06:28 AM   Best Answer
#5 DavieW
DavieW
  • 22 posts
Posted 21 December 2019 - 12:38 PM
Check the clutch fluid. You might have a leaking master or slave cylinder.
#6 timmy850
timmy850
  • 3,332 posts
  • Local Club: MITG
Posted 21 December 2019 - 09:57 PM
Check the clevis pin hasn’t fallen out of the top of the pedal
#7 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 29 December 2019 - 06:18 AM
Thank you!!
#8 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 29 December 2019 - 06:19 AM
Thank you all! I'll get under the car tomorrow night and report back!
#9 andyapanel
andyapanel
  • 624 posts
Posted 29 December 2019 - 12:32 PM
Its a long shot, but I had a flywheel toothed gear shift outwards recently.
It caused the same symptoms that you describe.
Good luck with tracking the fault down and let us know what it was.
#10 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 30 December 2019 - 07:28 PM
Hi Everyone,
There's a liquid on the ground where I park, and though she drips oil, it's a much bigger pool.  Unfortunately, it's dried up as I haven't driven her in a week now.
Also, with the car off, the clutch pedal travels fully, and I can move the shifter through all 4 gears.
Thanks,
Ryan
#11 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 30 December 2019 - 07:29 PM
Hi Andy,
Could you tell me how you were able to diagnose it?  And links or videos would help.
Thanks,
Ryan
#12 phillrulz
phillrulz
  • 617 posts
Posted 31 December 2019 - 01:50 AM
Hi Everyone,
Thanks,
Ryan
Checked clutch fluid level, sounds like a leak on the clutch, if the clutch doesnt fully decouple the engine you will struggle to chasnge gear when moving as your trying to drive the gears while still transmitting torque, Could be a split hose / bad slave .
#13 andyapanel
andyapanel
  • 624 posts
Posted 01 January 2020 - 01:01 PM
Hi Andy,
Thanks,
Ryan
It only became visible when the engine was removed.
It fell off when examined.
By that time it was useless and a new one was sweated on and spot welded.
#14 ryanlogsdon
ryanlogsdon
  • 108 posts
Posted 28 April 2020 - 02:43 AM
That's all it was.
I've also made the adjustment in my 1st DIY video.  Lot more DIYs and fixes to my Mini to come.
Thanks again everyone!
And to anyone looking in the future who wants to see the easy clutch adjustment, here it is in 2 minutes:
#15 GraemeC
GraemeC
  • 7,438 posts
Posted 28 April 2020 - 03:49 AM
Please treat yourself to some spanners
