Timing Chain Cover Gasket
Posted 27 December 2019 - 06:27 PM
Thank you ?
Posted 27 December 2019 - 06:41 PM
Posted 27 December 2019 - 06:56 PM
Posted 28 December 2019 - 10:10 AM
Thank you ?
Posted 28 December 2019 - 05:29 PM
Yes. I would only buy Borg&Beck or AP clutches.
Hi all another quick question is Borg and Beck any good as a brand I’m looking at there verto clutch kits on eBay ?
Thank you ?
Borg and beck is a good company, i wouldnt think twice about buying that brand.
But do you need the pressureplate aswell? Isnt it enough to buy the clutch plate from minispares?
Posted 28 December 2019 - 05:34 PM
Posted 28 December 2019 - 05:50 PM
I’m not sure I just found a full kit on eBay £100 it’s got the clutch, pressure plate and plunger thingy, I thought you had to change the lot ?
I would change the full kit as it's to get stripped to change a pressure plate and release bearing...
Posted 28 December 2019 - 06:18 PM
Posted 28 December 2019 - 06:54 PM
Posted 28 December 2019 - 09:02 PM
Just to mention I’m not replacing the flywheel just the clutch and pressure plate ???????
Edited by leepol83, 28 December 2019 - 09:29 PM.
Posted 28 December 2019 - 10:51 PM
clutch, bolts and plunger bit and re use the original pressure plate, will this do away with the need to balance it all????
Posted 28 December 2019 - 10:56 PM
If Verto get the assy. Balanced as they used to come pre balanced but do not any more. And they tend to be way out.
Posted 28 December 2019 - 10:58 PM
Edited by leepol83, 28 December 2019 - 10:58 PM.
Posted 29 December 2019 - 09:44 AM
Thank you ?
