More Sub Frame Problems
Posted 29 December 2019 - 01:00 PM
Posted 29 December 2019 - 01:47 PM
Do you mean the one through the heel board in to the sill?
Chances are there's some rust that's caused it to break free. You could cut a hole in sill end to investigate and gain access. Then take it somewhere to have a patch welded over & any other welding required once it's back on its wheels.
Posted 29 December 2019 - 02:02 PM
Posted 29 December 2019 - 02:05 PM
One way around this providing you can weld is to open the hole up enough to weld in flush a suitably sized nut.
However if there is enough material it may be possible to fit a Helicoil insert.
Posted 29 December 2019 - 02:21 PM
Posted 29 December 2019 - 02:36 PM
Hi guys, doing the rear sub mounts on the mini and whilst unbolting the front mount the threaded insert it threads into has completely detached its self completely. What's the best way to repair this so I can get it back together? Cheers
Mmm which bolt is this?
Posted 29 December 2019 - 02:51 PM
I've got a welder but I'm definitely a learner, I reckon there's 2/3mm of metal do you think that enough for a helcoil insert mate?
Nope not enough so you will need to go down the nut route.
Posted 29 December 2019 - 03:27 PM
Posted 29 December 2019 - 07:19 PM
Posted 29 December 2019 - 07:21 PM
Sorry mate not very Internet trained. Wrote the reply in the comment above. Cheers for you time/experience
