How Much Force To Press In Radius Arm Bushes?
11 replies to this topic
#1 NDT
NDT
  • 188 posts
Posted 12 January 2020 - 06:21 PM
Because I’m pressing some in using M12 threaded rod and it’s starting to strip the thread!
#2 Spider
  • 15,087 posts
Posted 12 January 2020 - 06:46 PM
Something's not right there !
You'd usually by able to just get them in on an M8 Allthread rod.
#3 Tupers
Tupers
  • 4,156 posts
Posted 12 January 2020 - 07:30 PM
As said above you should need very little pressure. I normally wind mine in with M8 all thread and 13mm spanner and the slide right in.
I’d imagine either your bearings are the wrong size or there’s something inside the bore that holding it off.
Time to pull everything apart and measure everything. If you’ve put enough pressure on the bearing to strip M12 threads you may have distorted the bearing now and it might need replacing.
#4 NDT
NDT
  • 188 posts
Posted 12 January 2020 - 09:12 PM
Something fishy going on.
This is a new set of bushes from minispares going into fairly clean bores in the radius arms.
#5 NDT
NDT
  • 188 posts
I’m not too worried about distortion as the bushes are going to be reamed anyway.
#6 Spider
  • 15,087 posts
Posted 12 January 2020 - 10:34 PM
Sure but I'd be worried about the Bush collapsing before you got it all the way in.
Without seeing them, the arms and measuring it's hard to say what's at issue here but doesn't seem right.
The Bushes, as you are already aware, are made from rolled material. If there's crud or a bur at the ends where they meet or indeed if they are not going in 'flat' on the ends but 'spiraling' even the slightest, they'll get bigger on the OD. I use a Press to fit them, but there's nothing in the world wrong with using threaded rod, as long as it's clean.
#7 NDT
NDT
  • 188 posts
Posted 12 January 2020 - 10:44 PM
Thanks for your help - I will have a I’m other look tomorrow.
Seems strange that I’ve had the same problem on both radius arms.
Either I’m doing something wrong or something else is at issue!
#8 NDT
NDT
  • 188 posts
Posted 13 January 2020 - 05:34 PM
Think I might extract them, buy some new ones, double check the finish and cleanliness of the area they're going into... and start again!
#9 Spider
  • 15,087 posts
Posted 14 January 2020 - 12:13 AM
Have you been able to get them started or are they only going so far and getting tight ?
#10 NDT
NDT
  • 188 posts
Posted 14 January 2020 - 06:34 PM
Getting really tight when halfway in.
The first one got all the way in apart from 3mm then I finished it off with a hammer.
#11 drs
drs
  • 21 posts
Posted 15 January 2020 - 03:56 PM
pop them in the freezer for a few hours, it makes them smaller!! well a small amount.
i always pop any pressed in bearing in the freezer before pressing in, they go in so much easier.
press in one go, dont stop.
paul
but it should not be as hard as yours, remove an do some measurements, bore gages and a micrometer
#12 Spider
  • 15,087 posts
Posted 15 January 2020 - 05:38 PM
Well,,, OK, I guess there in then !
