Filling and sanding
Posted 24 October 2006 - 06:06 PM
I'm prepping my mini for respraying at the moment and I'm wanting to know the best way to fill and sand minor dents etc. I'm wasting a lot of time by sanding and refilling etc as I always end up with slight ripples etc in the filler or I end up sanding off too much filler leaving a slight depression which then needs refilling :'(
I am sanding with wet and dry and mainly using the palm of my hand lightly to get the surface level - but it just never seems to happen.
It appears that all the surfaces are convex and with different radii so I can't make up a sanding block to match the surface!!
Any pointers would be appreciated,
spud.
Posted 24 October 2006 - 06:26 PM
Hope this helps and remember practice makes perfect!
Posted 24 October 2006 - 10:04 PM
JD
Posted 25 October 2006 - 06:12 AM
right ,remove paint from area to be filled and an inch all around
mix filler and apply and aim to leave it slightly proud ,
block this down (80grit DRY) when the surface is allmost right give it a fine coat of aerasole black paint and continue to block down (this is called a guide coat) now you can actuly see where is low
DO NOT RUB FILLER WET !!!!!
When the shape is right it is time to get the surface nice for this you need stoper
mix stoper and apply over the filler in a fine layer
block down this with 180 grit paper and guide coat
should now be ready for primer
when primered , guide coat and block with 800 grade paper wet (or dry with 400)
Posted 25 October 2006 - 10:32 AM
I'll take your recommendations on board!
What is special about 'stopper'? Is it just a super fine filler?
Cheers,
spud.
Posted 25 October 2006 - 04:41 PM
Posted 25 October 2006 - 06:59 PM
Posted 25 October 2006 - 07:28 PM
Why should you not rub it down wet?
because filler is one of the most absorbant materials man has created!!! if you rub down filler wet it will absorb moisture and it will soak thorugh to the metal, then when you think it's dry and paint over it, the moisture will try to escape, it will come back through the filler and lift off your fresh paint, but worse it WILL rot through the metal you fillered over.
so it's fairly important.
Edited by Retro_10s, 25 October 2006 - 07:29 PM.
Posted 25 October 2006 - 08:40 PM
Posted 26 October 2006 - 07:31 AM
I thought p38 was non absorbent? I know that polyfilla is absorbent but i though p38 was quite waterproof??
Posted 26 October 2006 - 09:37 AM
^^^Thats why I asked i thought the same^^^
Posted 26 October 2006 - 09:52 AM
But by all means, if P38 claims to be waterproof, go for it.
Posted 26 October 2006 - 03:05 PM
ive worked as a panel beater for 35+ years and every garage ive worked in all painters and body bashers have rubbed down wet for the finner grades of paper and never had a prob with water comming out as it was all dried out first.
