Camshaft For 998Cc Engine
12 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 17 January 2020 - 03:02 PM
hello
i need some advice for my car  998cc mini
just for using around town   and small journeys  no more than a 30/40km  jouerny
anyway my car has a mini spares stage one kit
new minispares lightended vertro clutch /flywheel
electronic distributor  .
so i have the engine out for a good rebuild
oil pump all bearing s etc
im so undecided for the camshaft   a sw5 swiftune or a kent 266
taking in mind i will be doing a engine bore to +10  flat top pistons and in the future a calver stage 3 head
so what do you people think is the best cam for my needs taking in consideration fuel and emmissions
thanks for any advice
#2 unburntfuelinthemorning
  • 1,983 posts
Posted 17 January 2020 - 03:15 PM
Kent 256 is a good all rounder for what you want;  very good fuel economy and increase in torque right through the rev range.
#3 OzOAP
OzOAP
  • 385 posts
Posted 17 January 2020 - 04:47 PM
Piper 255. Aim for 9.75cr when you get cylinder head. Lovely
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 17 January 2020 - 05:24 PM
Ive just fitted an ACD-rs in our Mini with a stage 3 head LCB and HIF38 runs very well
#5 cristiano1968
cristiano1968
  • 444 posts
Posted 17 January 2020 - 05:56 PM
I'll look in to.the Kent
256
#6 albirhiza
albirhiza
    Just On Tickover
  • Just Joined
  • 9 posts
Posted 17 January 2020 - 08:46 PM
I have an SW5-07 in mine. 295 head (skimmed for 9.5CR), 3.44 diff, lightened fly, minispares stage 1 (HS4 carb), recurved electric dizzy. Overall, i am pleased with the setup. Idles nice and smooth (turned up a tad to 1-1.1k) and pulls from idle to ~6k (haven't gone past this). No seat of your pants feeling when you pop on cam, but power is there. Easy to drive and great on both backroads and highways. I have no experience with other cams except stock A+, but i made all the changes at once, so it was a night and day improvement over stock A+ 998. I am curious about the Kent 246 and 256 for more lower down torque. Good Luck with the build.
#7 unburntfuelinthemorning
  • 1,983 posts
Posted 17 January 2020 - 09:04 PM
I used to have a 998 in the 1990s with a Kent 256 and a Minispares stage 3 head as they called it back then with a 3.44:1 final drive.  I used the vehicle for pizza delivery work so spent a lot of time buzzing around the city I worked in.  Great little engine, plenty fast enough for city work, economical, idled smoothly at 800 rpm, could rev to 6000 rpm, very fast from 0 to 45 mph, good fun out of town too but was never going to set the world on fire.  Would also cruise all day at 80 mph when necessary.  Overall fuel economy 40 mpg.
#8 Cooperman
  • 23,286 posts
Posted 17 January 2020 - 10:03 PM
The Evo 001 is very good in a 998, especially when fitted with a better head (ideally a 12G295) and improved inlet & ex. system.
#9 cristiano1968
cristiano1968
  • 444 posts
Posted 17 January 2020 - 11:31 PM
I appreciate all your ideas and experiences
#10 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 18 January 2020 - 03:36 AM
I like the Minispares EVO1, it's similar to the Kent 266....
Edited by Magneto, 18 January 2020 - 03:36 AM.
#11 luismx123
luismx123
  • 525 posts
Posted 18 January 2020 - 02:29 PM
im in the same boat, but looking more towards a ACD RS or even RS+... hmmmmmmmmmmmm
#12 Cooperman
  • 23,286 posts
Posted 18 January 2020 - 06:26 PM
The problem I have with cam selection questions is that there are so many companies trying to make a profit by selling 'their' cams that there is a lot of confusion caused.
For a competition car, where a few tenths of a second per lap or a second per special stage mile can be critical, then final selection is very important, but for a road car where such time improvements mean little, then selection between what are similar cams is just confusing.
You have to ask what you are trying to actually achieve. Remember, the cam only determines where the power and torque are delivered. More power can be achieved with a narrower power/torque band and gear ratios are also an important consideration.
For a road 998 you will probably be best with something like an Evo001 and a really good head at a CR of c.10:1. Gearing would best be a 3.44:1 FDR with standard gear ratios. An optimised induction & exhaust system is important and for good throttle response, my personal like is a pair of HS2's on a nicely matched inlet manifold.
At the end of the day what you are most probably seeking is a 'friendly' engine with good mid-range torque.
#13 cristiano1968
cristiano1968
  • 444 posts
Posted 19 January 2020 - 09:03 PM
Cheers coopperman
