Crack In Inner Wing. What Are My Options?
rust repair
#1 shish_happens
shish_happens
  • 34 posts
Posted 18 January 2020 - 04:17 PM
Hi all, just discovered this crack in the inner wing after getting it back from paint. So removing the whole front again and replacing the inner wing isn't really an option. So what do I do? My mate had a welder so I could give it a go myself or is a new panel a must? Thanks
Edited by shish_happens, 18 January 2020 - 04:18 PM.
#2 Tupers
Tupers
  • 4,156 posts
Posted 18 January 2020 - 06:17 PM
Welding it back together is fine as long as you’re a competent welder.
You should be replacing your rubber front subframe mounts while you at it as this sort of cracking only really happens when the mounts are shot.
#3 KTS
KTS
  • 2,457 posts
Posted 18 January 2020 - 08:07 PM
if that's the shock absorber i can see between the subframe tower and the inner wing, then it would appear you're missing a section of the inner wing ?
#4 shish_happens
shish_happens
  • 34 posts
Posted 19 January 2020 - 09:51 AM
That's the shock you can see yeah. I'll have another look at is
Also tagged with one or more of these keywords: rust repair
