R E S U R S
11 replies to this topic
#1 PACINO
PACINO
  • 764 posts
Posted 24 January 2020 - 08:45 PM
Hello! Anyone know this product? Pouring it into the oil; Reduces engine friction, compression is gained, and gas emissions are lower.
https://youtu.be/4ilGrz2eGGU
#2 nicklouse
  • 18,696 posts
Posted 24 January 2020 - 08:48 PM
And like all engine additives is very bad for your gearbox. Don’t add anything to your oil other than more oil as needed.
#3 PACINO
PACINO
  • 764 posts
Posted 24 January 2020 - 08:53 PM
Hello! Why is it bad for the gearbox? Bearings and syncs are robust parts.
#4 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 24 January 2020 - 09:19 PM
Not really as a mini has the gearbox in the sump and uses 20/50 oil so doesn't need any snake oil added. Plus I've had customers blow engines and gaskets using additional additives, mainly engine flush fluid though
#5 nicklouse
  • 18,696 posts
Posted 24 January 2020 - 09:24 PM
You want to make your synchros less effective then go ahead and add the *******.
reducing friction in an engine is good. But no good in a gearbox. People have been adding ******* to minis for years. And been changing gearboxes as well.
#6 Richie83
Richie83
  • 1,495 posts
Posted 24 January 2020 - 09:35 PM
Wise words.
#7 PACINO
PACINO
  • 764 posts
Posted 24 January 2020 - 09:36 PM
Ok, thanks for your answers. We could say then that the additive may be good for the engine, but in the case of the classic Mini that shares the same oil with the gearbox, it is not advisable to add anything. I put Valvoline 20w-50 on the last oil change. I think it is an acceptable oil
#8 Richie83
Richie83
  • 1,495 posts
Posted 24 January 2020 - 09:38 PM
VR1 is quality oil.
#9 PACINO
PACINO
  • 764 posts
Posted 24 January 2020 - 09:53 PM
I have exactly put this. And I like it as much or more than the Millers classic.
I don't know what you think.
#10 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 24 January 2020 - 10:00 PM
That is one of the best oils you'll get
#11 beardylondon
beardylondon
  • 1,618 posts
Posted 25 January 2020 - 09:21 AM
A friend works for a major oil company and they spend millions developing oils, and hence you don't want too screw with it. As said already, the Mini engine shares its oil with the gearbox, so leave well alone.
You are better off using the money the change the oil and filter more often with a quality oil.
#12 PACINO
PACINO
  • 764 posts
Posted 25 January 2020 - 01:25 PM
Thanks for your opinion.
