A+ Engine Rebuild - Should I Even Consider It?
15 replies to this topic
#1 Richie83
Richie83
  • 1,495 posts
Posted 08 February 2020 - 05:20 PM
I’m after some advice. Today I was lucky enough to pick up two A+ engines in need of rebuild. One of the engines has a shot gearbox. The other in need of piston rings amongst many other things. They are in a state for sure And as a total novice ive no idea where to start if I were to rebuild them.
What would I need to do? What would you do?
I’ve no need to build them at all by the way (touch wood) but kind of like the challenge.
#2 mab01uk
mab01uk
  • 12,419 posts
Posted 08 February 2020 - 05:35 PM
Try to get an original or copy of this DVD in links below......after over 4 hours of watching it you should have a good idea of what is involved in re-building an A-Series engine & gearbox, the tools required and whether you are up for the challenge:-
https://www.amazon.c...0/dp/B002HRYFSM
"Ultimate Mini Builder 1380 A series. Ultimate Mini Builder - 1380cc A-series is your comprehensive guide to building a high performance fast-road 1380cc A-series engine. With over four hours of in-depth footage, watch as Mini expert Bill Sollis strips a Metro 1275cc unit and then rebuilds it to 1380cc with all the perfect components for long-lasting and reliable power! And to prove the result, we run the engine on a dyno - revealing over 100bhp and 100lbs/ft of torque."
http://www.minispare...assic/T373.aspx
Edited by mab01uk, 08 February 2020 - 05:38 PM.
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,346 posts
  • Local Club: Amoc
Posted 08 February 2020 - 06:04 PM
As above.... also shows you how the gearbox works.
#4 sledgehammer
sledgehammer
  • 3,098 posts
Posted 09 February 2020 - 11:11 AM
as above - get the books & youtube
it looks like you have a bit of space
get an old digital camera & photograph everything you remove & where it goes
wash / clean / rust proof everything , then asses what you need to buy
sadly mini parts aren't as cheap as they used to be & quality is questionable - even on expensive components
assume new rings mean rebore & new pistons , could need new cam & followers , new bearings will be requires as well as oil seals & gaskets
cam chain & possibly sprockets & tensioner , may need valves & regrind
sadly not a cheap hobby if you want to do a good job
In my experience , everyone says get it reconditioned - a cheap recon will be a wash & paint
an £xpensive recon could be the same - so watch out who you deal with
sorry to be negative - but you are the only person who will do the job without needing to make a profit - so go for it
best of luck
#5 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 09 February 2020 - 11:33 AM
If you don't need to rebuild it, what have you got to lose? The fact is, you have no pressure etc. so you can just learn as you go. For me, that's a better scenario than needing it quickly for a car.
It might cost you a little bit in parts, so that's the only real consideration. However, if you document your process all the way through publicly, such as on here, you might even make a little profit selling it on afterwards. Alternatively, build a higher spec one with the intent of upgrading your current engine, or using it as a stop gap next time yours does need a rebuild.
I say go for it, and start a thread on here. I'd be interested to read it from the point of view of someone who doesn't have a clue what they are doing! When people are clearly very experienced and skilled in what they do, they can sometimes not maybe explain certain bits in the required detail for us novices.
Good luck!
#6 ADRay
ADRay
  • 97 posts
Posted 09 February 2020 - 12:36 PM
It’s a good opportunity to learn. I keep thinking of the “medical student / cadaver” analogy
#7 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 09 February 2020 - 02:30 PM
On the course I did when I was a youngster we just took the engine apart and put it all back together again on scrap engines. Cost nothing and was real good fun and you could learn how things worked. If you have no need for a recon engine that’s what I would do just for the fun of it
#8 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 10 February 2020 - 02:58 AM
Are you sure these are A+ motors? The left one has tappet chest covers and the right has an inertia starter....
Edited by Magneto, 10 February 2020 - 03:00 AM.
#9 mab01uk
mab01uk
  • 12,419 posts
Posted 10 February 2020 - 10:52 PM
998 A+ always had tappet chest covers and both blocks appear to have the A+ extra casting ribs.
Edited by mab01uk, 10 February 2020 - 10:54 PM.
#10 Magneto
Magneto
  • 889 posts
Posted 11 February 2020 - 05:59 AM
I did not know that on the 998, thanks!
#11 Richie83
Richie83
  • 1,495 posts
Posted 11 February 2020 - 06:31 PM
This is all great advice guys. I would like to have a go at it. And like the idea of having a thread. I’ll have a good read of anything I can find right now too.
#12 blacktulip
blacktulip
  • 6,224 posts
Posted 14 February 2020 - 08:44 AM
At least do one then you will know what you are going to be up against on the next one. I rebuilt an engine a few years ago and it wasn't that hard. Just pay lots of attention to detai with measurements and calculations, never cut corners and keep everything as clean as possible. I had a local machine shop do the parts for me and I built it up once all back. Enjoy it
#13 Richie83
Richie83
  • 1,495 posts
Posted 14 February 2020 - 08:43 PM
Sounds good. Did they paint it and whatnot for you too?
#14 blacktulip
blacktulip
  • 6,224 posts
Posted 14 February 2020 - 09:53 PM
It came back bare except for new core plugs so I painted it in satin black which turned out really nice. It took a good few evenings to build as I took extra time to check everything. It was so rewarding when it first fired up after checking for good oil pressure. It went well after the initial running in was complete. I say go for it.
#15 Cooperman
  • 23,286 posts
Posted 17 February 2020 - 04:31 PM
A lot of the perceived difficulty with engine building is how to do the calculations for compression ratios and amounts to be machined from block, etc., especially when you do some DIY gas-flowing.
It really is not as hard as some like to make you think and we are here to help. In fact, there are some good 'dodges' you can use to make it easier which we can come to later.
