Wheel Studs - Finding The Right Version
Posted 18 February 2020 - 10:34 PM
The original ones has a flat head to pass by the brake caliper. Now Ive contacted my dealer, but he says: there are only one type of studs on the market?! I should cut the head off a little bit. Now Ive done this, but the longer I look on those the more I want to search for longer studs with a flat head. Could you tell me If there is somewhere the right stud?
Original Cooper S brake stud (for 7.5 inch disc brake) with flat head, but longer, to fit the 10 mm spacers?
Please excuse my bad English.
Best regards from Germany...
Christop
Posted 18 February 2020 - 10:40 PM
Sorry don’t fit 10mm spacers. You either have the wrong wheels or arches. You can find longer studs that are correct but they are not from a Mini. Also you are limited to the length that you can fit due to the disc design.
so now onto your current studs what length are they?
Posted 18 February 2020 - 10:47 PM
Posted 18 February 2020 - 10:50 PM
https://allbrit.de/e...nummer=21A2064L
They would fit perfekt in length, but the head is the problem. I would need these but with flat head
Posted 19 February 2020 - 06:28 AM
Ive made some pictures, hope you can see the difference between the studs. Also I have grinded it down, in a professional way, with a lathe. But I think this is not safe!
Posted 19 February 2020 - 07:10 PM
Shouldn’t need grinding and should still clear.
That stud in your last picture is not pressed in properly
Posted 19 February 2020 - 10:21 PM
Posted 20 February 2020 - 11:54 AM
Like that?
Spacers are always a bad idea, but if you must at least don't mess with grinding or modifying.
At least you're not thinking of using extensions...
Posted 20 February 2020 - 01:56 PM
Judging from the OPs picture the issue appears to be the taper on the stud under the "head" and it isn't pushing into the hub far enough .. I've never seen any with "flatter" areas under the stud head so not sure what the correct advise would be .. I assume the stud holes in the hubs were checked for burrs, etc?
Posted 20 February 2020 - 10:16 PM
http://minispares.co...px|Back to shop
Like that?
That is what he has.
Posted 20 February 2020 - 10:20 PM
Why is it not possible to put spacers on the front axle/arches?
As Mr AllBrit says
Längere Bolzen um Spurverbreiterungen montieren zu können. Hinweis: Bitte beachten Sie, daß Spurverbreiterungen erheblich die Radlager belasten.
It also changes the scrub radii. Will make the handling worse. And many more things oh and you will most likely find the tyres will catch the metal work.
and as above that stud still has way further to go in.
Posted 21 February 2020 - 05:46 AM
Now I will send the whole bunch back to the dealer and I ve ordered the Cooper S Kit from another dealer! With longer studs;)
This time they should fit perfekt, so if Im using the correct Cooper S Brake disc ;) and I think, yes without spacers it works best. But this is the problem: it now should work 10 times better with 5x10 original Exacton wheels with An offset of 15.5 and only 10 mm spacers instead of driving the original 6x13 inch monster wheels with ugly arches! This is more bad for the wheel bearing.
