Crank Thrust Washer Thickness
8 replies to this topic
#1 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 26 February 2020 - 01:29 PM
just wondered thickness the standard crank thrust washers are?
#2 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 26 February 2020 - 03:18 PM
About 2.34 mm (googled it .. figures from a MMOC forum post! https://www.mmoc.org...pic.php?t=59014 )
#3 1314cc
1314cc
  • 303 posts
Posted 26 February 2020 - 06:33 PM
does the crank need to be completely removed to fit new thrust washers?
Only recently refitted my gearbox to the block only to notice 12 thou end float on the crank ,whilst changing the timing plate gasket.
Before I took on the half moon seal job the engine was running sweet @80bhp and has covered around 20,000 miles. That's over 20 years or so. Up until last september it was off the road for 6 years.
#4 1314cc
1314cc
  • 303 posts
Posted 26 February 2020 - 06:39 PM
it's frustrating to think that only 2 weeks ago I had the block and crank sat in front of me! Picture I took a couple of weeks back
Edited by 1314cc, 26 February 2020 - 06:46 PM.
#5 1314cc
1314cc
  • 303 posts
Posted 26 February 2020 - 06:52 PM
another recent picture, don't know whether anyone can see anything potentially wrong? Certainly only one of the washers is clear to see? Guess it's just my camera angle
I'll be splitting the swine apart at the weekend!!
Edited by 1314cc, 26 February 2020 - 06:53 PM.
#6 KTS
KTS
  • 2,470 posts
Posted 26 February 2020 - 08:22 PM
Don't think the crank has to come out - if you remove the centre bearing cap and upper thrusts and rotate the crank the lower thrusts should follow the crank as it rotates so you can extract them.
#7 Minigman
Minigman
  • 779 posts
Posted 26 February 2020 - 08:42 PM
You don’t need to remove the crank to do the thrust washers.
#8 1314cc
1314cc
  • 303 posts
Posted 26 February 2020 - 08:48 PM
thanks for the replies. I'll get back with what I find!
#9 Rorf
Rorf
  • 866 posts
Posted 27 February 2020 - 06:22 AM
You have got this far I would strip the engine again so you can check all bearings and maybe just replace the rings. 12 thou crank clearance is massive and there might be wear on the crankshaft thrust bearing face. One needs to aim for 2 to 3 thou clearance.
Another main cause of excessive wear here could be incorrectly set up clutch or a pressure plate that is too strong.
Strip everything and measure all journals and bearing clearances.
