Starter Motor To Flywheel
3 replies to this topic
#1 jmwood900
jmwood900
  • 25 posts
Posted 02 March 2020 - 05:55 PM
I'm trying to workout which starter motor I need (number of teeth) to match my flywheel. I have a lucas starter motor older type and the engine won't turn over via the starter. I have tested the starter, which is good. The battery is good and I replaced the solenoid for good measure to no avail. It seems that the starter is engaging but not able to turn the flywheel. Any ideas please it's driving me mad
#2 nicklouse
  • 18,998 posts
Posted 02 March 2020 - 07:13 PM
What type of flywheel do you have? Or how many teeth does it have.
Same info for the starter?
#3 jmwood900
jmwood900
  • 25 posts
Posted 02 March 2020 - 07:16 PM
I have 11 tooth starter, will have to check on the flywheel
#4 floormanager
floormanager
  • 791 posts
  • Local Club: Mini Club Sussex
Posted 02 March 2020 - 08:48 PM
11 teeth is wrong for an inertia starter.  9 is for old minis, sometimes a 10 tooth gets fitted as it was fitted to Metros I believe.  11 tooth is wrong.  Age of mini and type of engine would help
