How To Remove Cooper S Window Trim Safely ?
6 replies to this topic
#1 KRDraper
KRDraper
    Just On Tickover
  • 6 posts
Posted 02 March 2020 - 06:28 PM
I'm rebuilding a 65 Cooper S and before I paint want to take the chrome window
trim off the doors. Have no idea how to do that safely so I can reinstall later.
Any help would be appreciated
Kent
#2 absx2
absx2
  • 920 posts
Posted 02 March 2020 - 07:00 PM
Starting at the top of the frame use the thin wide blade to pop the press studs off and then work down both sides but leave the lower sections, then slide the trim upwards to remove.
The bottom two clips if original slide into the trim, the others work the same as press studs and pop away.
#3 KRDraper
KRDraper
    Just On Tickover
  • 6 posts
Posted 02 March 2020 - 07:07 PM
Thanks Super Mini Mad :)  what about the trim under the window?
#4 blacktulip
blacktulip
  • 6,224 posts
Posted 02 March 2020 - 08:25 PM
Look in the felt channel for small screws. I think there are 4. Then hold the glass in front of each other, pull the channel towards the inside of the car and it should come away.
#5 Daz1968
Daz1968
  • 2,058 posts
Posted 02 March 2020 - 11:52 PM
If you mean the outer lower trim it just lifts off after removing the upper surround. Clips are not very strong so easy to lift
#6 Cooperman
  • 23,327 posts
Posted 03 March 2020 - 12:09 AM
After doing any restoration work it is a good idea to delete the 'buttons' onto which the door window surround chrome trim is fitted. Tiger-Seal is ideal for fixing the trim. Just apply the Tiger-Seal into the inside of the chrome trim, place it against the door and secure it temporarily with tie-wraps. leave for 24 hours, remove the tie-wraps and trim off any excess adhesive with a plastic knife.
There will then never be any rust under the trim.
#7 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 04 March 2020 - 08:45 AM
If it has the original fixings there are two different types.
Along the top edge and down the angled part of the front - except the bottom one - they are a cup type fixing which the trim pops over. Pop the trim off these first.
The lower front and vertical rear fixings are like a raised washer and the trim should be slid straight upwards over these.
