Rusty Water-Heated Inlet Manifold
Best Answer panky , 09 March 2020 - 03:11 PM
I had the same thing on my '91 Cooper. It's been by-passed for the last ten years without a problem.
You can just see the length of copper pipe I used as a by-pass. It could do with being a bigger diameter but it's been fine all these years.
Go to the full post
5 replies to this topic
#1 AlasdairM
AlasdairM
  • 240 posts
Posted 09 March 2020 - 01:53 PM
Hi (1275 carb Cooper 1990)
One of the ports of my inlet manifold is rusty (and will probably leak). It seems like I have 2 options:
1. Buy http://www.minispare...|Back to search which has 1/2' outlets (mine has 5/8' outlets) and adapt current hoses to fit.
or
2. Bypass the heated inlet manifold completely. Does anyone have any experience of doing this? Or any threads which show what was done? I'd be interested to see the techniques.
Alasdair
  • Attached File  123.jpg   119.99K   4 downloads
Edited by ali.m.1, 09 March 2020 - 01:53 PM.
#2 panky
panky
  • 1,791 posts
Posted 09 March 2020 - 03:11 PM   Best Answer
Edited by panky, 09 March 2020 - 03:15 PM.
#3 AlasdairM
AlasdairM
  • 240 posts
Posted 09 March 2020 - 03:38 PM
Haha that is exactly what I had in mind: Copper pipe it is!
thanks
#4 panky
panky
  • 1,791 posts
Posted 09 March 2020 - 03:47 PM
I compressed an olive on either end then cut the backing nut off, stops the hose popping off the end.
#5 AlasdairM
AlasdairM
  • 240 posts
Posted 09 March 2020 - 04:00 PM
Ok thanks. And did you plug the inlet manifold ports, or just leave them open?
#6 panky
panky
  • 1,791 posts
Posted 09 March 2020 - 10:17 PM
Just left them open.
