Austin Mini 1000 City E Engine Number Confusion
Best Answer smurfomatic , 21 March 2020 - 08:26 PM
Guess Works engine number decoder gives the following:
Source Vehicle : Mini
Engine type & CC : A+ 998 cc Transverse mounted
Fueling :
Engine features : Lucas 16AC alternator with -ve Earth
1st Alternative compression ratio
Mechanical petrol pump
ADO 20 Design variants
Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints
2.95:1 Final Drive
Go to the full post
4 replies to this topic
#1 proccy13
proccy13
  • 34 posts
Posted 21 March 2020 - 08:19 PM
Hi everyone,
I've moved from restoring and finishing a 1965 Triumph Spitfire to restoring a 1983 Austin Mini 1000 City E 998cc. I just wanted to look into the engine number a bit more, I've used this website - https://www.minimani...on_Data_UPDATED and found out that it matches the V5 being a 998cc engine.
My engine number is 99H997P  153089.
The website above says -
99H/997        1980 onward A+ block, flat top pistons, economy fitment with 2.95 final drive
99H/A97P      A+ block with dished pistons, pre-A+ gears, 3.44 final drive & 12-inch wheels
Therefore, my engine number '99H997P' matches - '1980 onward A+ block, flat top pistons, economy fitment with 2.95 final drive' BUT what does the P mean following the '99H997'?
Hope that makes sense,
Thanks, Oli
#2 smurfomatic
smurfomatic
  • 461 posts
Posted 21 March 2020 - 08:26 PM   Best Answer
Fueling :
2.95:1 Final Drive
#3 proccy13
proccy13
  • 34 posts
Posted 21 March 2020 - 08:56 PM
Fueling :
2.95:1 Final Drive
Thanks!
#4 smurfomatic
smurfomatic
  • 461 posts
Posted 21 March 2020 - 09:08 PM
No problem
#5 Davetom
Davetom
  • 39 posts
Posted 13 July 2024 - 08:12 AM
Deleted due to error
Edited by Davetom, 13 July 2024 - 10:31 AM.
