Primary Gear Oil Seal Puller
12 replies to this topic
#1 Minigman
Minigman
  • 779 posts
Posted 30 March 2020 - 06:23 PM
I’m hoping someone can help me out with a oil seal puller.
I have the Sykes Pickavant tool for installing one but not for getting one out.
If anyone has the puller part or the whole lot for sale and can post it I’d be interested.
#2 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 30 March 2020 - 06:30 PM
You don't need any puller. It's a seal, screwdriver/chisel on one side it will pop out or screw a self tapper into it.
Edited by jonny f, 30 March 2020 - 06:31 PM.
#3 Minigman
Minigman
  • 779 posts
Posted 30 March 2020 - 06:44 PM
A self tapper isn’t a bad shout I guess. I tried levering it’s but not happening.
#4 bartman
bartman
  • 265 posts
Posted 30 March 2020 - 07:12 PM
you pull the seal out with the primary gear, thats how the genuine churchill primary gear seal puller works.
#5 Minigman
Minigman
  • 779 posts
Posted 30 March 2020 - 07:45 PM
I appreciate that bu haven’t got one hence why I was aking for one.
#6 nicklouse
  • 18,697 posts
Posted 30 March 2020 - 07:58 PM
some on Ebay but they are missing the parts needed to use it to pull the primary gear. so be careful if are going to buy one.
https://www.ebay.co....3IAAOSw0yJeckpd
Attached File  Capture.JPG   66.18K   6 downloads
#7 Minigman
Minigman
  • 779 posts
Posted 31 March 2020 - 02:40 PM
I wound a wood screw into one side of the seal and pulled it out. Thanks for the tip Jonny F.
#8 bartman
bartman
  • 265 posts
Posted 01 April 2020 - 09:02 PM
they pop up on ebay quite often.
#9 nicklouse
  • 18,697 posts
Posted 01 April 2020 - 11:03 PM
But often incomplete.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 02 April 2020 - 06:55 AM
The Sykes-Pickavent ones also crop up often and they have less bits to be lost. In fact as long as you get the outer shell the rest is easily made up. Much easier to use too.
The sets with the puller and the seal installer together are a nice bit of kit.
Edited by GraemeC, 02 April 2020 - 07:05 PM.
#11 Minigman
Minigman
  • 779 posts
Posted 18 April 2020 - 12:22 PM
With further problems and the engine now back in the car I’m looking to pull the seal and primary gear again whilst in situ.
I can’t find a traditional puller anywhere and can’t ‘pull off’ the screw in the side of the seal method this time due to the angle I’m working at.
I’ve put a wanted post out but if anyone has used any other puller to do the job please let me know.
#12 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,042 posts
Posted 18 April 2020 - 12:55 PM
If you have access to a welder then you could make one like I've made below, doesn't have to be tube you could use 3 or 4 lengths of metal around the radius
 I used some 65mm ID tube cut it up and made the bolt end for it out of 6mm plate and the other a U shape with a ~48mm ID to match the gear groove and I welded together and drilled and tapped it M12. which got us something similar to the standard tool, used an old main bolt and drilled it a little to centre the tool bolt. and gave it a lick of paint
7F76C6DF-A5E9-429C-87BD-71DAE5A44D73_zps
599D25D0-9A96-4B07-AD89-6A8D6A870BC6_zps
#13 Minigman
Minigman
  • 779 posts
Posted 18 April 2020 - 01:11 PM
That looks great but I have no access to any of this at the moment sadly.
