hi i am having trouble with the indicators and hazard lights on my 1980 layland mini, only one side worked when i turned on the hazards or indicated, so we got a new flasher unit but it still doesn't work, so i followed the cables up along the loom an tested the indicator again, by attaching a wire to the prong on the flasher unit and touching it to a stripped section of the indicator loop, and it worked so i'm pretty sure there is no break in the cable, but the switches still don't turn on one side of the car can anyone give advice on what to do please?
Posted 05 April 2020 - 03:06 AM
Posted 05 April 2020 - 09:48 AM
Posted 05 April 2020 - 09:57 AM
A 1980 Min will have separate indicator & hazard flashers, but both are used for both sides of the car.
Does the car have a centre speedo by any chance? See what happens if you pull out the bulb holder for the indicator warning lamp.
Posted 06 April 2020 - 12:45 AM
yes it does have a centre speedo, will give it a go thankyou very much
Posted 06 April 2020 - 08:38 AM
...it should be made of plastic because the bulb must not earth on the housing.
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
Mini Technical Sections →
Problems, Questions and Technical →
Understanding The Starting System / AlternatorStarted by Jaybraham , 18 Feb 2025 ![]() |
Identifying Wiring Diagram/loomStarted by Jaybraham , 02 Feb 2025 ![]() |
![]() Are Auxiliary Switches (Fog,hazard Etc) Supposed To Be Backlit At Night?Started by leehine54 , 31 Jan 2025 ![]() |
Which Ignition Coil?Started by daddums , 27 Jan 2025 ![]() |
