Mini Engine Number
14 replies to this topic
#1 Harrydewhurst
Harrydewhurst
  • 10 posts
Posted 11 April 2020 - 05:11 PM
Got a mini yesterday and don't know any information about it. Its a bit boy Racerish. The engine no is BHM1272F/E if anyone knows any information it would be much appreciated! Thank you
#2 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 11 April 2020 - 05:49 PM
I tried here, but the engine number you have doesn't seem to fit the format.
Guessworks
What year/model is it?
#3 nicklouse
  • 18,585 posts
It is a gold seal replacement engine.
more info on what engine it is will enable us to give more info.
#4 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 11 April 2020 - 05:51 PM
Can you double check to see if it is actually BHM or BMH?
Open to correction but I believe it would've been a replacement engine such as a silver or gold seal.
#5 Harrydewhurst
Harrydewhurst
  • 10 posts
Posted 11 April 2020 - 05:56 PM
It is 1989 mini thirty but it's not very original looking I don't think it's the original engine. Its definitely BHM
#6 Harrydewhurst
Harrydewhurst
  • 10 posts
Posted 11 April 2020 - 05:57 PM
Where the silver/gold seal engines painted gold or silver?
#7 nicklouse
  • 18,585 posts
Posted 11 April 2020 - 05:59 PM
BHM is correct.
#8 nicklouse
  • 18,585 posts
Yes
#9 nicklouse
  • 18,585 posts
Posted 11 April 2020 - 06:00 PM
So it is a 998
Edited by nicklouse, 11 April 2020 - 06:00 PM.
#10 Harrydewhurst
Harrydewhurst
  • 10 posts
Posted 16 April 2020 - 11:39 AM
Its not a 998 as I said before it's definitely had a replacement engine it's at least 1275 just wanted more info on when and where the engine came from if possible
#11 timmy850
timmy850
  • 3,331 posts
  • Local Club: MITG
Posted 16 April 2020 - 11:47 AM
If it's a BHM number it's a factory gold/silver seal engine as mentioned above. These aren't fitted to new cars, they are new/reco engines bought from BMC if you need a new one
#12 Harrydewhurst
Harrydewhurst
  • 10 posts
Posted 16 April 2020 - 11:54 AM
Thank you timmy! Maybe if I scrape back the black paint on the engine it will be silver /gold underneath, what is the difference between silver/gold?
#13 Mark506
Mark506
  • 61 posts
Posted 24 April 2020 - 08:00 PM
I'm just about to swap out the 998 in my mini for a 1275 unit. I'm just looking at what I need to do for getting the V5 changed and for this I need to provide a engine number. The ID plate is long gone, so any suggestions what to do for this?
#14 Minigman
Minigman
  • 779 posts
Posted 25 April 2020 - 01:00 PM
You can make up a number of your own choice.
As far as changing capacity on the V5 it can be tricky. They’ll want a garage receipt for the engine build indicating the engine cc or an engineers report.
The times I’ve changed my engine I’ve just not bothered. If you do the job yourself why should you have to pay for someone else to inspect it? Presumably they take the head off to measure the bore and stroke to confirm the capacity.
Edited by Minigman, 25 April 2020 - 01:03 PM.
#15 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 28 April 2020 - 09:20 AM
The level of recon .. gold was a full engine, and silver just the short block. My A35 has a gold seal .. the lot was resprayed: block, head, sump and end-plates.
There should also be a couple of letters stamped into the engine plate which would indicate the amount of overbore and crank re-grind. If that is accurate mine had a 20thou rebore but a massive 40 thou off the crank!! I'll check when it's stripped .. it's seized anyway after over 40 years of sitting in a garage.
