Kad Quickshift Won’T Go Into Gear.
Best Answer knowell , 14 April 2020 - 09:31 PM
I think I found the problem. Is this bottom plate on wrong?
5fyBXaz.jpg Go to the full post
11 replies to this topic
#1 knowell
knowell
  • 27 posts
Posted 14 April 2020 - 03:48 AM
Installed a genuine KAD Quickshift and unable to get into 3rd gear. 4th and reverse also seem a bit difficult to shift into but do shift into gear. I don’t know how the mechanism works inside in order to possibly modify it to shift properly. Any help would be appreciated.
Note- I removed the entire gearlever box and mounted the base of the KAD ensuring that bolts are in the proper position. Also the linkage is pointing with the cup facing downward u shape.
Photo to compare the old and new shifter
Edited by knowell, 14 April 2020 - 04:40 AM.
#2 nicklouse
  • 18,600 posts
Posted 14 April 2020 - 08:06 AM
You will be just trying to move the lever too far across the gate.
takes time to get it right..
also check for witness marks on the bottom plate That it is not catching. Or remove potion plate and check all gears can be selected.
#3 MrE812
MrE812
  • 39 posts
  • Local Club: ELMOC
Posted 14 April 2020 - 05:27 PM
I have the very same quickshifter fitted.
I too had trouble but in my case the problem was the yoke being inverted.
Should be this way round...
otherwise there's not much adjustment needed.
The body of the shifter should be firmly seated onto the housing.
I'd be surprised if the KAD item fouled on anything though - it should be a simple direct replacement.
#4 knowell
knowell
  • 27 posts
Posted 14 April 2020 - 06:24 PM
Hi yes, that is the cup I was referring to and is positioned the way you mention cup downward like a U. Also I ensured to mount the base with the two bolts going in the pins used to be. Thank you for the input
#5 Spider
  • 14,893 posts
Posted 14 April 2020 - 06:29 PM
If you have the rubber bellows fitted at the coupling, that can stop it.
#6 knowell
knowell
  • 27 posts
Posted 14 April 2020 - 06:49 PM
If you’re referring to this rubber gaiter I decided to take it off thinking the same but It didn’t fix the issue . If this isn’t the rubber bellow you’re referring to. Could you please reference a picture thanks!
Edited by knowell, 14 April 2020 - 06:55 PM.
#7 knowell
knowell
  • 27 posts
Posted 14 April 2020 - 07:31 PM
Here is a photo of it mounted to the gearlever box
#8 MrE812
MrE812
  • 39 posts
  • Local Club: ELMOC
Posted 14 April 2020 - 08:16 PM
Yep, that's a KAD quickshift.
You'll never get it into gear though - because the gear stick is sitting outside the car!! ( :lol:  sorry)
It looks like you're fitting it correctly.
If the original gear stick fits and the gearbox works correctly in all gears then then I'm not sure what might be causing the problem for you with the quick shift.
The throw of the KAD stick is quite different and does take getting used to but I prefer it.
#9 knowell
knowell
  • 27 posts
Posted 14 April 2020 - 09:31 PM   Best Answer
#10 nicklouse
  • 18,600 posts
Posted 14 April 2020 - 09:36 PM
errr first reply.
#11 knowell
knowell
  • 27 posts
Posted 14 April 2020 - 09:48 PM
errr first reply.
Thanks nick, I’ll remove it and flip it around. Hopefully that’s the issue
#12 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 15 April 2020 - 11:58 AM
The bottom plate also houses the reverse lock-out. If you turn it around you might find you have to lift for 1st and can go into Reverse instead of 4th by accident. Be sure to check all that as well.
