Fitting P700 Headlamps
8 replies to this topic
#1 wiltona79
wiltona79
  • Just Joined
  • 49 posts
Posted 15 April 2020 - 05:16 PM
Hi,
I have a 1994 Mayfair and want to know if I swap my current headlamps for P700's do I need to change the wiring harness and headlamp bowls?
I have seen online you can buy just the healamps or a complete kit.
Any advice please.
#2 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 15 April 2020 - 05:48 PM
The kit only has bulbs and a cover for the wiring. The headlamp bowls are the same.
You might have to modify the sidelight wiring but I'm sure my 93 cars both had Halogen as standard. The dipped, main beam and earth wire are the same from Sealed beam or Halogen.
Hope this is some help.
Edited by cal844, 15 April 2020 - 05:51 PM.
#3 wiltona79
wiltona79
  • Just Joined
  • 49 posts
Posted 15 April 2020 - 06:27 PM
Cheers, I'll start with just the headlamps then and see how far I can get
#4 SugarCrashedPupski
SugarCrashedPupski
  • Just Joined
  • 39 posts
Posted 15 April 2020 - 09:41 PM
I swapped my lights over for P700s and look great on the car but you will have to modify the sidelight wiring but it's fairly straightforward once you get into it.
#5 wiltona79
wiltona79
  • Just Joined
  • 49 posts
Posted 16 April 2020 - 05:21 AM
What exactly did you have to do?
#6 krev2_1
krev2_1
  • 10 posts
Posted 16 April 2020 - 08:47 AM
Also interested in this, sorry for hi-jack
Do these have a better beam than standard pre93 lights ?
#7 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 16 April 2020 - 09:47 AM
They give a better beam. I'd say to use Osram bulbs as they give a brighter light.
Just a small amount of wiring, to extend the wiring and fit to the new sidelight fixing
#8 Mini Manannán
Mini Manannán
  • 2,857 posts
  • Local Club: man Estate
Posted 16 April 2020 - 08:15 PM
Osram Nightbreaker H4 bulbs are great!  They really do make a difference. Philips X-treme are supposed to be slightly better, but either bulb will be worth the money.
#9 cal844
cal844
  • 9,632 posts
  • Local Club: TFMOC
Posted 16 April 2020 - 09:41 PM
That's the ones Osram Nightbreakers... I have a set on my Clubman Estate, one can see the difference in lumens and beam spread compared to generic bulbs
Edited by cal844, 16 April 2020 - 09:41 PM.
