Damaged Inner Cv Joint Or Gearbox Problem?
8 replies to this topic
#1 Oskifisk
Oskifisk
  • 16 posts
Posted 16 April 2020 - 07:09 PM
Hey Forum
My mini from 1977 is making a click click click noise when I drive, the noise is from right wheel/gearbox. The car took a hard hit to the side of the wheel. I stopped the car lifted it and tried to spin the wheel while in neutral, there is no clicking sound from my left wheel, but there is from the right. Is it a faulty inner cv joint? I'm learning towards inner cv, but I just need some clarification before I go buy a new one
Thanks in advance
Edited by Oskifisk, 16 April 2020 - 07:11 PM.
#2 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 16 April 2020 - 07:21 PM
Its highly likely you've damaged some of the suspension components, possibly also the outer cvt joint. This is the one that sits behind the wheel and these tend to click when they wear or are damaged. They're usually noisier when the wheel is steering on full lock where the joint is then under the most stress.
I'd jack the car up and safely support it then have a good thorough inspection around the suspension and hub for anything obvious.
Cheers, Steve.
Edited by Stevie W, 16 April 2020 - 07:22 PM.
#3 Oskifisk
Oskifisk
  • 16 posts
Posted 16 April 2020 - 07:31 PM
Thanks for the fast respond Steve
I have lifted the car and turned the wheel by hand, the noise is coming from the gearbox, I have listened to the outer cv and it seems okay. The hit was directly from the side, it was a slide to the curb. And you might be right about the suspension but haven't noticed any damage
Thanks again
#4 Stevie W
Stevie W
  • 1,204 posts
Posted 16 April 2020 - 08:35 PM
You might want to see if the noise is coming from the pot joint (inner cv). If not and its definitely coming from the gearbox, I would suspect the differential. Was everything ok before the wheel was hit?
Cheers, Steve.
#5 Spider
  • 15,041 posts
Posted 16 April 2020 - 08:43 PM
I'd suggest disconnecting the drive shaft from the Inboard CV, then spinning the hub and then the Inboard CV and you'll soon hear which is making the noise.
I hope it's the CV ,,,,,
#6 Oskifisk
Oskifisk
  • 16 posts
Posted 16 April 2020 - 09:29 PM
If it is the diff, shouldn’t both wheels click when they are spinning? Even by hand, or is that the whole purpose of the diff
Im getting a bad feeling now...
Thanks guys
Edited by Oskifisk, 17 April 2020 - 09:58 AM.
#7 Stevie W
Stevie W
  • 1,204 posts
Posted 17 April 2020 - 06:53 PM
If you jack up both wheels and spin one, the other should spin in the other direction without any undue noise from the differential. Any noise, roughness or excessive play when changing wheel rotation direction denotes an issue with the planet gears or diff pin inside the cage.
Whilst up on axle stands and secure, you could try selecting 1st gear with the engine running on tick over and see if there's any undue noise coming from the diff. Don't get underneath the car though for safety sake, but any issue with the diff or final drive should be apparent.
Cheers, Steve.
#8 Oskifisk
Oskifisk
  • 16 posts
Posted 28 April 2020 - 12:21 PM
Tuned out to be the pot joint, got that changed and the clicking sound stopped. Thanks for your help guys.
#9 Stevie W
Stevie W
  • 1,204 posts
Posted 28 April 2020 - 02:32 PM
Glad you got it sorted and thanks for posting what the issue was. Its always nice to hear of a good outcome!
Cheers, Steve.
