Hi guys I could do with some advice. I have recently built up 1275 A plus engine. All ready to fit but I thought I would engage the clutch to check. When it is engaged it seems to be putting pressure on the crankshaft and slowing it down with some resistance . I’m rotating it by hand with a ratchet. The flywheel/ clutch and back plate was brought complete assembly from MED. it is an inertia st2 assembly .
The crank has all just been reground to plus “20 with new bearings etc. End float is all within limits. Along with primary gear.
i have checked and rechecked everything I can think of but still no joy.
any advice would be welcome as I’m running out of ideas ?
cheers
joe
