Electronic Ignition And Ballasts
Best Answer ACDodd , 23 April 2020 - 06:54 AM
Ethel no, back in the day factory coils used 1.4 to 1.5ohm windings. Since then the supply has change to 0.9ohm winding on the same part number. Its the usual story of cheap parts. I now fit a viper dry coil with 1.5 ohms from power spark with no ballast on the 65d units. If you fit a 1.5 ohm coil set the plug gaps to 0.035" you will feel difference in more part throttle torque. If you by a coil by the original part number it won't be the correct resistance.
Ac Go to the full post
14 replies to this topic
#1 ben.mini
ben.mini
  • Just Joined
  • 46 posts
Posted 22 April 2020 - 09:34 PM
Hi All,
A topic that i know has been covered in some way, but has I haven't managed to find an answer to my specific question. So here goes:
I have a 1990 Flame Red, A previous owner has installed an MG Metro Engine into her. It has an electronic ignition system the 65DM4, the Ignition Coil has on it '09-220 Electronic Coil' written on it. The mini originally has a ballast ignition system, (the loom has a Pink and white wire with resistive written on it.)
The previous owner/s have connected the ballast system to the coil and the 65DM4 to the coil.
Coil Resistance reads 0.9 ohms. When running the coil has 10V to earth from positive contact.
My questions are?
Should the 65DM4 not be supplied with a 12V supply and not the 10V from the coil +ve?
Is this coil correct? Should a ballast system coil be used? can a ballast system coil be used with electronic ignition?
Any info would be welcome.
Ben
#2 ACDodd
ACDodd
  • Mini Docs
  • 2,772 posts
Posted 23 April 2020 - 05:54 AM
Ok the coil you have has too low primary resistance. You need 1.5ohms. No ballast resistor is used with the 65Dm4 dizzy.
Ac
#3 Ethel
  • 26,187 posts
Posted 23 April 2020 - 06:46 AM
It sounds like the correct, factory, fitted coil GCL183 or DLB198 from Lucas it should have a 1ohm primary coil. I know AC uses 1.5ohm coils.
 Expect it would work as it is, but it would be better without the ballast, especially if there's no bypass supply from the solenoid.
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,772 posts
Posted 23 April 2020 - 06:54 AM   Best Answer
Ac
Edited by ACDodd, 23 April 2020 - 06:57 AM.
#5 ben.mini
ben.mini
  • Just Joined
  • 46 posts
Posted 23 April 2020 - 09:36 AM
Thanks Guys! This has helped confirm my thoughts!
So I will look for a new 1.5 Ohm Coil.
Just to check, In terms of removing the ballast, I would run a new wire from the ignition switch to the coil and 65d unit (obviously choosing the correct rating). And disconnect the ballast from both ends. This way the ballast is out of the system.
It does have a bypass lead from the starter solenoid. I guess that should also be removed, but won’t really cause any issues if left either.
Again
#6 ben.mini
ben.mini
  • Just Joined
  • 46 posts
Posted 23 April 2020 - 10:45 AM
Ac
Would you have a link to the Coil you suggest AC?
I have had a look on the power spark website, but am a little confused as all of hate 1.5 coils say for use with a ballast.
Thanks.
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,772 posts
Posted 23 April 2020 - 10:58 AM
Yes I use the 1.5 without a ballast but only on the 65d dizzy. All others must use a ballast resistor.
Ac
#8 ben.mini
ben.mini
  • Just Joined
  • 46 posts
Posted 23 April 2020 - 11:34 AM
Thanks Ac!
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,772 posts
Posted 23 April 2020 - 11:44 AM
The factory did this as well. The same coil was used on the ballast ignition contact breaker type.
Ac
#10 cal844
cal844
  • 9,674 posts
  • Local Club: TFMOC
Posted 23 April 2020 - 09:00 PM
You can just remake the connection at the fuse box end of the resistor wire, I used Piggyback spade connections at the fuse box and a butt connection where the resistor wire connection was.
#11 ben.mini
ben.mini
  • Just Joined
  • 46 posts
Posted 24 April 2020 - 09:24 PM
Some feedback for you. I bought a Viper 1.5 Ohm Coil, gapped the plugs, rewired (removed the ballast), and timed her up. Starts first turn of the key, revs freely and idles well. Just need to take her for a run to the shops tomorrow. Thank you for the advice Ac.
#12 ACDodd
ACDodd
  • Mini Docs
  • 2,772 posts
Posted 24 April 2020 - 10:00 PM
Glad all is good!
Ac
#13 croc7
croc7
  • 825 posts
Posted 26 April 2020 - 05:08 AM
So that’s a straight 12v to the ignition module?
#14 ben.mini
ben.mini
  • Just Joined
  • 46 posts
Posted 28 April 2020 - 07:19 AM
Yes, New 12V feed to the Coil and feed to the ignition module from the coil +ve.
#15 croc7
croc7
  • 825 posts
Posted 29 April 2020 - 04:35 AM
Thnx
