Gear Stick Notchy When Clutch Pressed
4 replies to this topic
#1 1314cc
1314cc
  • 303 posts
  • Local Club: tumbleweedminisbristol
Posted 25 April 2020 - 10:07 AM
So new clutch fitted.I haven't road tested yet as the mini is not taxed. All gears feel fine but when the clutch pedal is pressed all gears can feel a bit notchy. It will go into each gear though.
I haven't bled the slave cylinder since fitting the new clutch , waiting for my daughter to assist me!
Any thoughts...?
#2 nicklouse
  • 18,724 posts
Posted 25 April 2020 - 10:42 AM
why do you need to bleed the clutch?
what clutch? exactly the same as the old one? you have rested the appropriate settings?
#3 1314cc
1314cc
  • 303 posts
Posted 25 April 2020 - 12:17 PM
verto clutch. Just thought to bleed it to rule out air in the system.
It's a brand new clutch kit.
When the engine is running and clutch is pressed the gear changes sometimes feel notchy.With ignition off the gears feel fine
#4 nicklouse
  • 18,724 posts
Posted 25 April 2020 - 01:02 PM
If it worked before then you have no reason to bleed it as you have not opened it.
Set the stop nuts to 6.5mm?
Edited by nicklouse, 25 April 2020 - 01:03 PM.
#5 1314cc
1314cc
  • 303 posts
Posted 25 April 2020 - 01:05 PM
yes I've set the stop at 6.5mm
Probably need to properly test drive it first?
