Hi I have just purchased a 1989 mini with a 998cc engine fitted, I am fairly new to mini’s so bare with me on the tech details please. The engine is running but very loud. Previous owner has said he believe it has bent a push rod on cylinder 1. My question is if I am going to replace this pushrod( if this is even the fault??) should I replace all the rods in the engine? And anything else I should do while doing so?
Cheers in advance for putting up with my naivety.
3 replies to this topic
Posted 26 April 2020 - 11:11 PM
Posted 27 April 2020 - 07:59 AM
Well first I would be inspecting the two pushrods. I would be surprised if one is bent.
Posted 27 April 2020 - 09:19 AM
You can replace which ever one(s) is bent, but if that is the issue, you'd want to find out why it / they bent before just fitting replacement pushrod(s).
Posted 27 April 2020 - 09:37 AM
Might be worth checking clearances first. One may just be tight or loose.
Mini Technical Sections →
Problems, Questions and Technical →
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
Milky Oil In Rocker After Not Draining Water Before Removing HeadStarted by jezjsa , 11 Mar 2024 engine |
