Could someone please explain to me the pros and cons of fitting a beam axle instead of subframe and am I right in thinking that you could use just the front of the subframe.If this has been covered before I apologise.
Beam Axle Or Subframe.
Posted 28 April 2020 - 04:32 PM
Posted 28 April 2020 - 04:54 PM
If you are circuit racing:-
The Pros are less weight and less inside rear grip when cornering.
The Cons are work and expense.
You would fabricate much lighter suspension mounting points than the front portion of a subframe.
Posted 28 April 2020 - 06:35 PM
A “Beam” axel
road car no pros at all.
cons, linear rate coil springs will Reduce usability of the car such as only two people and no luggage. Rear arches need reinforcing. The schlock mount is not designed for the load and will bend.
a subframe
car can be used as designed.
chopping up a subframe. Sure but yo7 would have to make sure it can no longer pivot on the front mounts. Not light.
Posted 28 April 2020 - 06:43 PM
This TMF thread in link below maybe of interest.
Mini Beam Axle:-
http://www.theminifo...mini-beam-axle/
From Dave Vizard's Book:-
Edited by mab01uk, 28 April 2020 - 06:46 PM.
Posted 28 April 2020 - 07:01 PM
Thank you very much for your replies.Its something I read about and didn't really understand.
