My plan is to replace the pipe from LCB to CAT with a new connector pipe that has the 'flex' section in order to install a sensor for an A/F Ratio Gauge, any risk of the 'flex' portion interfering with the rod change mechanism?
I then plan on installing a twin box CAT BACK Maniflow 1 3/4" exhaust system to replace the current single R40, I want this Mini as quiet as possible for a Mini as I expect to be making 200 mile runs fairly regularly.
Thanks in advance.
