Cv Joint Clip Rubs On The Hub On Mk1 Mini
11 replies to this topic
#1 AliG13
AliG13
    Starting My Mini Up
  • 4 posts
Posted 10 May 2020 - 07:21 AM
Hi all, I’m rebuilding the drive shafts on my mk1 Cooper,it has the small type cv joints ,I’ve fitted the large clips supplied but when I fit the hub the clip stops it rotating, I have replaced the clip with wire and this seems to work.Has anyone come across this problem cheers.
#2 imack
imack
  • 2,110 posts
Posted 10 May 2020 - 07:26 AM
I use these type of bands, but you need the tensioning tool to install them. Nice low profile clamp.
#3 AliG13
AliG13
    Starting My Mini Up
  • 4 posts
Posted 10 May 2020 - 07:45 AM
Cheers where do you get them from.
#4 timmy850
timmy850
  • 3,339 posts
  • Local Club: MITG
Posted 10 May 2020 - 08:41 AM
Any generic parts shop. It's a "cv banding tool"
Edited by timmy850, 10 May 2020 - 08:53 AM.
#5 FlyingScot
FlyingScot
  • 2,664 posts
Posted 10 May 2020 - 04:09 PM
If you can’t find anywhere nearby that’s open. Amazon have them
FS
#6 tegski
tegski
    Starting My Mini Up
  • 3 posts
  • Local Club: ACT Mini Car Club
Posted 17 May 2020 - 12:28 AM
I am about to try some SS ties that come from Bunnings (local hardware chain in Australia - auto section) They are like cable ties but have a much lower profile as they use a small ball bearing to jam the overlapped section from moving backwards. Also they were $4 for a pack of 10. :-)
#7 FlyingScot
FlyingScot
  • 2,664 posts
Posted 22 May 2020 - 08:33 AM
Moved from fuel injection to “normal” tech section for more interest
FS
#8 Spider
  • 14,885 posts
Posted 22 May 2020 - 11:50 AM
Long ago I found this issue.
I use tie wire or stainless steel cable ties.
Another option is a 'Flatie' Cable tie. CBS have these, but use two of the smaller ones as the bigger ones are too wide.
#9 Findrake
Findrake
  • 14 posts
Posted 11 June 2020 - 06:29 AM
I saw these as well: how did you get on? Worth a try or not?
#10 Spider
  • 14,885 posts
Posted 11 June 2020 - 10:42 AM
The thing with the Stainless Ties is getting them tight enough, When pulled up, because of the way they lock, they actually 'slip' back a far bit compared to just about any other tie. I could never really get them tight enough using ordinary tools, you really need a cable tie gun that's suitable for stainless ties to get these tight enough.
#11 Magneto
Magneto
  • 889 posts
  • Local Club: KC MINI Club
Posted 12 June 2020 - 03:07 AM
Agreed. I found some flat style plastic cable ties on amazon, and they are the correct width - they don't stand up when tight so they clear the inner hubs....work a treat. I'll see if I can come up with the part number....
The description is "ACT 14" low profile cable ties"  Part number AL-14-50-LP-O-C  (ACT = Advanced Cable Ties)
Package of 100 cost about $15 US IIRC
Current type on amazon - different brand but similar style  https://www.amazon.c...s/dp/B07G1DWCZT
ACT brand on another site....  https://www.electric...ylon-cable-ties
And I found the ACT website....  https://www.advanced...4-inch-natural/
Edited by Magneto, 12 June 2020 - 03:10 AM.
#12 Spider
  • 14,885 posts
Posted 12 June 2020 - 03:18 AM
CBS also have a similar type
https://www.carbuild...e-ties-100-pack
though, you need to link 2 together to get the length for the big end of a CV joint. They do have longer types, but they are too wide to be effective.
I have tried these and I thought they were ~ OK ~, but I wasn't over the moon about them.
