Removing Engine - Disconnecting The Driveshaft
Best Answer MiniMadRacer , 12 May 2020 - 09:38 AM
breaking the top taper and releasing the arm allows the hub to pivot on the bottom ball joint and the track rod end basically swing the hub towards the rear of the car
Go to the full post
14 replies to this topic
#1 kkeith
kkeith
  • 83 posts
Posted 12 May 2020 - 08:39 AM
Hi,
Removing engine for a gearbox rebuild. All going well considering first time doing It. Last major part to do is the driveshaft. Question is, to get to it do I need to remove the entire hub or just separate the ball joints and undo the suspension arms? A short how to guide some be great as the Hanes manual hasn’t helped in this case.
Thanks!
#2 kkeith
kkeith
  • 83 posts
Posted 12 May 2020 - 09:19 AM
Hi,
Thanks!
Sorry I mean disconnecting the pot joints
#3 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 12 May 2020 - 09:27 AM
i break the top ball joint and release it from the taper> this allows the hub to be dropped  down enough to release the drive shafts from the gear box
#4 kkeith
kkeith
  • 83 posts
Posted 12 May 2020 - 09:29 AM
Ah ok, then I just need to separate the pot joints from the diff (with the tool).
Thanks - I was trying to avoid having to take the whole hub off but sounds like I don’t need to.
Edited by kkeith, 12 May 2020 - 09:30 AM.
#5 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 12 May 2020 - 09:34 AM
if removing the pot joints with the tool< make sure you drain the oil first
#6 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 12 May 2020 - 09:38 AM   Best Answer
#7 28hodge
28hodge
  • 223 posts
Posted 13 May 2020 - 10:22 AM
I have just done this and just undid the top ball joint as suggested and dropped the hub over, then used a drift and hammer on the pot joint and one good clean strike shocked them over the clip no problem
#8 johnR
johnR
  • 2,302 posts
Posted 13 May 2020 - 11:20 AM
I've done this fairly regularly recently - I just raise the engine a little then lever the rad side driveshaft out of the diff followed by the other (drain oil first) No need to disconnect suspension.
#9 kkeith
kkeith
  • 83 posts
Posted 20 July 2020 - 05:32 PM
Thanks to everyone that helped. I ended up taking the hub off and changing inner and outer CV joints. Seems every job I do, I find another one is just around the corner! :-)
#10 whistler
whistler
  • 1,818 posts
Posted 20 July 2020 - 06:43 PM
You can lift the engine out without undoing any suspension. The pot joints are designed to slide back on their splines enough for you to gently lift and seperate both sides.
#11 kkeith
kkeith
  • 83 posts
Posted 22 July 2020 - 10:30 AM
Yep, trouble is I found the CV's to have to much movement and needed replacing anyway. Just added to the fun! Cheers
#12 nicklouse
  • 18,689 posts
Posted 22 July 2020 - 11:02 AM
The CVs do not move on their splines as they are located by the C clips. But there internals can move to compensate for the driveshaft length change due to suspension movement. Only the early ones had the big fat sliding splines.
#13 whistler
whistler
  • 1,818 posts
Posted 22 July 2020 - 03:27 PM
Perhaps I should have said the driveshaft moves back on its splines.
#14 Spider
  • 15,106 posts
Posted 22 July 2020 - 07:32 PM
I've always left the Pot Joint on the Gearbox and separated the Drive Shaft from it. I know that does mean splitting the Top Ball Joint, but it does leave the Engine / Gearbox as a sealed unit.
I have seen engine outs as some have suggested here by separating the Joint from the Gearbox and I can see that's a doodle to get the Engine out, however, I've not done it that way (might try it on my next), but how do you guys find refitting the Engine with this method ? Just thinking about it, it looks like it could be a fiddle to get the engine at just the right height to start them off or is there a bit of leeway here ?
#15 28hodge
28hodge
  • 223 posts
Posted 30 July 2020 - 10:33 AM
I found relocating the pot joints simple enough, engine dropped to the correct height to locate a pot joint and then o just shoved the engine across to engage it, once done lift the other pot joint to the correct height and then let the engine drop back and centre itself and it’ll drop into the opposing pot joint.
Only thing I didn’t do was fully tighten the ball joints they were only hand tight, so when I put oil into the engine with the car still up on axle stands the pot joints/shafts had enough drop on them to mean the point joints weren’t fully seated and allowed oil to drip out, one the ball joints were tightened up that stopped.
My only issue is now is it won’t start, despite spark and fuel so guessing timing is out to far
Edited by 28hodge, 30 July 2020 - 10:34 AM.
