Austin Bonnet Badge 1967-1970
12 replies to this topic
#1 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 23 May 2020 - 07:35 AM
Maybe a long shot but does anyone know of any for sale?
#2 sca
sca
  • 25 posts
Posted 23 May 2020 - 07:59 AM
try ebay under bmc mini parts for sale
#3 Chris1275gt
Chris1275gt
  • 960 posts
Posted 23 May 2020 - 08:00 AM
Here's one not cheap though.
https://www.ebay.co....uIAAOSwYSFerVxr
#4 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 23 May 2020 - 08:14 AM
Thanks chaps, yes its it bit pricey for a reproduction badge.
Appreciate you sourcing it all the same though, will keep an eye out for an original but I might have my work cut out.
There are a couple abroad but extortionate money.
Edited by owenlcr, 23 May 2020 - 08:30 AM.
#5 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 23 May 2020 - 08:33 AM
When I needed a front and back badges and bezels  for my MK2 I got genuine ones from Ebay eventually. I ended up getting them from 2 different sellers over a period of time. As we all know with Ebay it is luck if it has a lot of bidders or not
I wondered if they were the same badge as used on the bonnet of the 1300 range (and might be cheaper if listed for those) as anything with Mini on it seems to push the prices up these days.
#6 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 23 May 2020 - 08:41 AM
Possibly, I will keep an eye out, must admit I never thought to look at the 1300, will have a check
#7 steeley
steeley
  • Just Joined
  • 623 posts
Posted 23 May 2020 - 09:07 AM
Back in the day my mum had an Austin A40 the steering wheel horn push was the same as this,wether or not it is the same or similar size I don’t know
#8 steeley
steeley
  • Just Joined
  • 623 posts
Posted 23 May 2020 - 09:10 AM
There are a couple on eBay at about £35
Edited by steeley, 23 May 2020 - 09:15 AM.
#9 dodge44
dodge44
  • 53 posts
Posted 23 May 2020 - 09:44 AM
The two examples so far illustrated here have a pretty incredible plastic insert as most are heavily crazed like this one so you may have to settle for a less than perfect example. AFAIK the part has never been available as a reproduction item so the item advertised as that may be 3D produced if that is possible with clear items? You can conceal the crazing on these with WD40, but you obviously need to keep adding more every so often.
Roger
https://ibb.co/rML9rqF
Edited by dodge44, 23 May 2020 - 09:44 AM.
#10 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 23 May 2020 - 12:22 PM
I did have a look at these but I believe they are a larger diameter, thanks all the same
Edited by owenlcr, 23 May 2020 - 12:23 PM.
#11 owenlcr
owenlcr
  • Just Joined
  • 65 posts
Posted 23 May 2020 - 12:25 PM
Roger
They are very good examples and I would indeed be exceptionally fortunate to locate one like this, would like to get one in fair condition and will keep an eye out, the WD40 tip is good to know, thanks
#12 sansamn
sansamn
  • Just Joined
  • 47 posts
Posted 26 May 2020 - 08:57 AM
I’ve picked up a few on eBay for around £40. Just a case of waiting I’m afraid
The one I have fitted to my Mini was a little crazed when I got it but a light going over with some jeweller’s rouge brought it up lovely
Attached File  Badges.jpg   66.29K   5 downloads
#13 EAVB
EAVB
  • 27 posts
Posted 03 June 2020 - 08:08 PM
PM on its way
