Removing Cylinder Head
5 replies to this topic
#1 rock1day
rock1day
  • 74 posts
Posted 24 May 2020 - 01:23 PM
Can the cylinder head be removed (decoke) with the thermostat / thermostat housing left in place or will this cause problems when refilling the coolant?
My car is 28 years old and I'm concerned about shearing off the thermostat housing studs.
#2 nicklouse
  • 18,757 posts
Posted 24 May 2020 - 01:25 PM
it can be left on. but i would be changing the thermostat if it has not been done for a long time.
as you are taking the head off it makes it easier to take it somewhere if there are issues.
Plusgas and heat are useful tools.
#3 Rorf
Rorf
  • 866 posts
Posted 24 May 2020 - 03:59 PM
Definitely change the thermostat, the thermostat housing and the studs too. Otherwise a half job done which will bite you in the *sse later on :shy:
#4 rock1day
rock1day
  • 74 posts
Posted 24 May 2020 - 08:14 PM
Makes sense, would the bolts be easier to remove if the engine is at running temperature or is direct heat from a blowlamp more effective?
#5 MiniMadRacer
MiniMadRacer
  • 897 posts
Posted 25 May 2020 - 08:49 AM
Direct gentle heat from a blow lamp and plus gas or similar, but watch your face if spraying plus gas or similar onto hot studs as it can flash or spit at you.. I also find a soft mallet to gently tap the housing, "up and down" to kind of rock it on the studs to free off the "rust / binding".. and as always.  take your time.. spray.. drink tea.. water the garden etc... contrary to popular belief these rust pentrating fluids take a long time to act not 5 mins :-)
i have a "gorilla" mate who sprays a rusty nut then snaps it off almost immediately and slags of the fluid for being useless..
#6 rock1day
rock1day
  • 74 posts
Posted 25 May 2020 - 12:34 PM
Thanks for the advice, think I`ll try direct heat plus a freeing agent for several times before attempting to remove the studs.
