Knocking When Lifting Off Accelerator
11 replies to this topic
#1 20Drift
20Drift
  • Just Joined
  • 10 posts
Posted 25 May 2020 - 10:17 AM
Hi all,
Had an issue which has been driving me mad trying to find, just looking for some pointers!
Mini is a 1986 Mini Mayfair 998cc.
When coming off the accelerator sharply, I get a very loud knocking sound which sounds like it's coming from the firewall. I've been doing some hunting and checked the following...
  • Subframe mountings to the footwell are not cracked - they've had reinforcement plates welded before. Using a pry bar on the underside gives no movement at all (rubber mounts being used)
  • Subframe mountings to the top of the strut towers under the bonnet are solid
Whilst I was jacking the car up from the front teardrop mount, I noticed the bushing looks a bit worse for wear:
When jacking it up, that bush deflected a fair bit more than the passenger side. I've also noted the front tie rod bushes are cracking, so I'm wondering if this is the cause?
It was booked in at the garage before corona kicked in, so not sure when it'll go down to have a look at properly. I want to get it over an inspection pit and have someone look under it when it knocks to see if something obvious is moving! Any pointers in the mean time will be much appreciated.
#2 sonscar
sonscar
  • 3,198 posts
Posted 25 May 2020 - 10:34 AM
Grab hold of the rocker cover and rock the engine,see if it moves.Put it in gear Not Running and rock the car back and forwards to see if the engine moves.!Steve..
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
More than likely the engine steady bushes are worn or the bracket has snapped. how much does the engine move when you push it back and forwards? it could be the carb hitting on the bulkhead which may have bent the jet.
#4 20Drift
20Drift
  • Just Joined
  • 10 posts
Posted 25 May 2020 - 11:16 AM
Sorry should have added - tried the rocker cover Trick but the engine barely moves. Definitely not enough to hit the carb on the bulkhead
#5 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 25 May 2020 - 11:19 AM
Under load the engine moves much more, personally change both stabilizer bushes
#6 20Drift
20Drift
  • Just Joined
  • 10 posts
Posted 25 May 2020 - 11:39 AM
Interesting hadn’t thought of this. Will have a check later
#7 andyapanel
andyapanel
  • 642 posts
Posted 25 May 2020 - 11:50 AM
+1 for top engine steady
#8 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 25 May 2020 - 12:38 PM
I had a similar problem on mine and it went away after I changed the lower arm suspension bushes which had deteriorated. Worth checking the lower arm and tie bar bushes
#9 20Drift
20Drift
  • Just Joined
  • 10 posts
Posted 02 June 2020 - 07:40 PM
Just an update for you all... couldn’t track down the issue with the car on jack stands or ramps, so took it down to the local garage as they have an inspection pit.
They found when letting off the clutch, the rear passenger side mount for the front subframe is coming away from the body. Looks like the rubber has come away from the metal. Currently got two new rear mounts on order and two front teardrops as well. Hopefully that’ll sort it!
Thanks for all the tips!
Edited by 20Drift, 02 June 2020 - 07:42 PM.
#10 Algordo1100
Algordo1100
  • 774 posts
Posted 02 June 2020 - 08:16 PM
That's good it's getting sorted.
It will certainly drive better too with the subframe held on properly! :)
#11 MiniMadRacer
MiniMadRacer
  • 899 posts
Posted 03 June 2020 - 06:22 AM
Side issue.. dont jack the car up under the tie rod bracket,,, sooner or later you will bend that tie rod
#12 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 03 June 2020 - 09:15 AM
I do, however only if I really have to, if my jack wint go under the subframe to my preferred lift point. I do however have two Jack's so life is slightly easier
