Where To Fit A Malpassi Filter King.
10 replies to this topic
#1 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 26 May 2020 - 02:53 PM
As above chaps really.
Where are you mounting a Malpassi Fuel Regulator ?
In the Boot...
On the Rear Subframe...
Under the Bonnet...
Id like to fit mine under the bonnet somewhere, any pics would be great.
Cheers. Dicky.
#2 imack
imack
  • 2,184 posts
Posted 26 May 2020 - 03:11 PM
Behind the radiator on mine.
#3 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 26 May 2020 - 04:23 PM
+1 for behind the radiator!
Cheers, Steve
#4 nicklouse
  • 18,662 posts
Posted 26 May 2020 - 05:04 PM
Close to the carb, but anywhere that is not the boot.
#5 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 27 May 2020 - 07:38 AM
Cheers all. Behind the Rad it is then.
#6 panky
panky
  • 1,792 posts
Posted 27 May 2020 - 09:22 AM
#7 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 27 May 2020 - 02:53 PM
Anyone know what the Malpassi pressure is set at from the factory ?
#8 I hate Brian
I hate Brian
  • 782 posts
Posted 27 May 2020 - 03:47 PM
You need a gauge that screws in the top to set the pressure
#9 KTS
KTS
  • 2,456 posts
Posted 27 May 2020 - 07:54 PM
looks like it's set wide open from the factory - as above, you'll need a pressure gauge to set it to a specific value
http://www.officinam...nsaboutitem.pdf
#10 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 08 June 2020 - 08:02 PM
Just to add some more info to this.
Had a deep search through the internet...think it was on an MG forum. It seems that Malpassi Regulators come Pre-Set at 3psi. Ideal for my twin HS4s.
So, fitted the new glass bowl regulator and all working very well. (Mine has'nt got a fitting for a Gauge)
#11 Ethel
  • 26,029 posts
Posted 09 June 2020 - 08:04 AM
Close to the carb means less pressure loss between regulator & carb. Ideally you'd want higher pressure from the pump to the regulator because it can't increase pressure to get the steady 3psi you want.
3psi would be a 286cm head of petrol, so not impossible to do with a ladder 'n length of pvc hose  :D
