best way to remove underseal?
Posted 28 October 2006 - 01:38 PM
the mini is now just a bare shell and i can turn it on its side quite easy.
i was wondering if there is any attachments for a 9" angle grinder that might do the job?
also i want to remove all the old paint ready for a repray, so again , is there any way to do this with an angle grinder with the correct 'blade' . (some kind of attachment that will remove paint but not damage the metal)
heres hoping.....
dan.
Posted 28 October 2006 - 01:45 PM
does anyone know how i can remove underseal on my mini?
heres hoping.....
dan.
try a wire brush attachment
Posted 28 October 2006 - 01:55 PM
Or you could always heat it up and scrape it off? Sometimes it scrapes off quite easily when it's dry and flaky or you could soak it in white spirit for a while.
Whatever way its a pretty arduous task but quite worth it
Posted 28 October 2006 - 02:04 PM
Posted 28 October 2006 - 02:39 PM
Also a good idea to turn the car on it's side, but this may not be possible.
Posted 28 October 2006 - 02:42 PM
Posted 28 October 2006 - 02:55 PM
if you mean removing the paint from the car body and not from were you have took the underseal off use paint stripper or a paint removing disc that fits on grinders, i cannot remember the correct name for it but i think machine mart sells them, they take the paint off and dont do a lot of damage to the metal.
Posted 28 October 2006 - 03:10 PM
Posted 28 October 2006 - 03:31 PM
Posted 28 October 2006 - 07:05 PM
i can easily get the mini on its side so scraping the underseal off should be a bit easier than normal.
Posted 28 October 2006 - 07:11 PM
all of the above, plus some nitromors paint stripper helps too!!
that stuff is great. but damn it burns.
Posted 28 October 2006 - 07:13 PM
on a serious note tho try the heat and scraper option or maybe petrol/paint thinner/paint stripper and a scraper
