998Cc Engine Start Trouble
8 replies to this topic
#1 MasterMind
MasterMind
    Just On Tickover
  • 7 posts
Posted 29 May 2020 - 09:30 AM
Hi, I own a 1990 998cc mini city. The engine has been rebuilt with a 1987 head.
When I go to start it, it turns over fine and at speed (don't think it's the starter motor). Most of the time, I do manage to get it started with a lot of fiddling with the choke and throttle. The timing is set to 8°, the mixture is OK.
Also when I do get it started it sounds like it is running on 3 cylinders until I bring the revs up slightly and keep them up until it clears up (usually takes between 5 and 10 seconds)
Any suggestions
#2 cal844
cal844
  • 9,627 posts
  • Local Club: TFMOC
Posted 29 May 2020 - 01:09 PM
What cam has been fitted?
#3 MasterMind
MasterMind
    Just On Tickover
  • 7 posts
Posted 29 May 2020 - 01:29 PM
Stock cam (not sure on specific but its the same one it came with) . The only modifications to it are a stage 1 kit (high airflow filter, smaller needle, manifold, exhaust) and electric distributor.
Edited by MasterMind, 29 May 2020 - 01:30 PM.
#4 gdcarpenter
gdcarpenter
  • Just Joined
  • 43 posts
Posted 29 May 2020 - 01:46 PM
For what it’s worth I have a 1990 Mini Mayfair 1000 with an original John Cooper Conversion, so very similar to your Mini. I find mine starts, idles, and drives best with timing about 16 degrees BTDC. Might be worth trying more advanced timing.
#5 cal844
cal844
  • 9,627 posts
  • Local Club: TFMOC
Posted 29 May 2020 - 03:01 PM
Put more advance in, just enough to get it started
#6 MasterMind
MasterMind
    Just On Tickover
  • 7 posts
Posted 29 May 2020 - 03:09 PM
I'll give it a go
#7 MasterMind
MasterMind
    Just On Tickover
  • 7 posts
Posted 29 May 2020 - 03:10 PM
Will do
#8 MasterMind
MasterMind
    Just On Tickover
  • 7 posts
Posted 29 May 2020 - 05:27 PM
All fixed, turns out it was a snapped wire from the coil to the starter motor, fixed it and put in a new set of plugs and started up instantly
Thank you though
#9 cal844
cal844
  • 9,627 posts
  • Local Club: TFMOC
Posted 29 May 2020 - 05:50 PM
Thank you though
Good man, thanks for letting us know the fix
