Hi;
A friend of mine is trying to build up a spare front subframe to transplant into his mini when it come back from spraying after a fire. He managed to pick up a second hand Front Subframe which came with Top and Bottom Arms, Tie Bars, Hi Los and Disc Hubs.
He has removed the Hubs and at first thought one was a Drum Hub but now thinks they are both Disc Hubs but they are not the same?
How many different types of Disc Hubs are there and how can you tell the difference?
He will be running 8.4 Calipers.
Here is the only pic I have:
The hub on the right has a chamfered outer and the one on the left has a stepped outer?
The ones I have for my project (also making up a front Subframe) looks the same as the one on the left - I will be running 7.5 Caliper Disc Brakes
Edit I have just spotted that the one on the right may well be a Metro Hub, looks like he's been sold a duff setup (bit like mixing radials and Cross Plys ![]()
Edited by JonnyAlpha, 31 May 2020 - 08:40 PM.
