Hello
I'm in a huge bodywork on the Mini and I have to questions. I started to build up the door frame first, I have to replace all the panels at the door post. I bought heritage panels. With the floor panel in place and secured by screws the boxing plate (ALA5688) does not fit to the edge of the floor, but it fits good at the upper end and to the dash. On the pictures you'll see the left side, the right side has the same issue.
Should I cut the inner panel and shortening it ? What is your opinion ?
door1.jpg 41.01K
9 downloads
door2.jpg 38.86K
5 downloads
Other question is about the stiffener panel ALA6473 and the door step/post panel HMP441012. The stiffener has two "faces" which are in contact to the door post panel ( The 3rd face has the holes for the door hinges)
Both these two face has to be spot welded to the door post panel ?
I hope you'll understand what I want to ask ![]()
