Hi All,
So my Mini hesitates under light throttle. I can be driving along, a nice cruise, but if I press the throttle lightly to speed up the engine hesitates. If almost feels like a misfire but not. Giving it more throttle to full throttle normally cures it until next time. This happens in all gears and is not dependant on RPM.
The engine is a 1275 from an MG Metro. I have set the timing by idleing at 2000 rpm adjusting till revs stop rising then back off a bit, took for a drive and backed a little more off due to pinking (65D dizzy). The carb is a HIF44, have checked oil in the dash pot and topped up.
I am trying to work if it is ignition or carburettor related. Could the oil be too light in the dashpot? Could the spring be too light and the hesitation being caused by the damper opening too quick? Or the jet set too lean at lower throttle openings? Or could it be the timing advance? Well I mean they are all the things in my head, but I am struggling to put an order to them.
Has anyone seen anything similar or could give any insights?
Ben
