10 Inch Wheels With 7.5 Inch Discs
9 replies to this topic
#1 steeley
steeley
  • Just Joined
  • 623 posts
Posted 02 June 2020 - 04:28 AM
I know the its been asked before as I can find some old posts but I can’t seem to get a definitive answer
I have bought and just about to fit the mini sport 7.5 inch disc kit,
I am looking to run 10 inch steel wheels Without arches
Some posts say cooper s, some say any and do I need drum spaces to the rear?
What are my wheels and tyre options?
Edited by steeley, 02 June 2020 - 04:31 AM.
#2 luismx123
luismx123
  • 525 posts
Posted 02 June 2020 - 06:51 AM
A friend of mine has the cooper S replica alloys from JBW. Theyre 4.5x10 with ET 32 i believe. They almost just fit under the arches completely. The tread is covered, the wall of the tyre isnt. You can compare wheels and tyres on willtheyfit.com
An example would be the Rosepetals 4.75x10 with ET40. Theyre 2mm further in than the cooper S replicas I believe. Hope this helps
#3 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 02 June 2020 - 07:42 AM
I have the Mini Spares MSSK013MS
BRAKE CONVERSION KIT 8.4" TO 7.5" BRAKES USING MS CALIPERS on mine, with the C-21A1968
WHEEL, MINISPARES 4.5x10 SILVER NEW TYPE WHEEL 'S' OFFSET. They fit, neatly, within the arches without spacers.
Edited by Quinlan minor, 02 June 2020 - 07:45 AM.
#4 KTS
KTS
  • 2,462 posts
Posted 02 June 2020 - 02:27 PM
yes - spacered drums go with disc brakes
the offset of the wheel will determine whether or not you should fit arches
a 4.5" S rim has an offset of ET36 and sits within the wheel arch, a 4.75" rosepetal is approximately 6mm wider, but the mounting flange is 4mm closer to the outer rim (ET40), so the outer rim sits 1mm further inboard than an S rim
a simple rule of thumb is that for every half inch (12mm) you add to the rim width, you'd need to add about 6mm to the offset (..of the S rim..) to keep the outer rim in the same relative position as an S rim
#5 luismx123
luismx123
  • 525 posts
Posted 02 June 2020 - 04:22 PM
i thought the S offset wheels are ET32... would like to find one with 36
#6 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 02 June 2020 - 04:43 PM
Yes, mine, from Mini Spares, are ET32 Offset.
#7 KTS
KTS
  • 2,462 posts
Posted 02 June 2020 - 08:20 PM
i was referring to Dunlop LP883's, which according to wheeldictionary, have ET36 offset
#8 steeley
steeley
  • Just Joined
  • 623 posts
Posted 02 June 2020 - 09:00 PM
So if I go with 4.5 inch rim I need an offset of around +35
Can I fit 165 tyres or would I need 145
#9 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 02 June 2020 - 09:19 PM
I run 165/70/10 on 4.5" Offset ET32
(pictured above)
Edited by Quinlan minor, 02 June 2020 - 09:35 PM.
#10 KTS
KTS
  • 2,462 posts
..anything up to about ET30 on a 4.5J rim should be fine
you can fit 165's on a 4.5" rim.
