Have changed timing cover gasket but still got a leak at that end of the engine. Any thoughts as to where might be from as loosing patience. Not a confident spanner man self taught and Haynes manual. All help appreciated. Thanks
Oil Leak Still
Posted 04 June 2020 - 09:04 AM
Posted 04 June 2020 - 09:23 AM
Half moon seal behind the timing chain plate, between engine and gearbox.
Posted 04 June 2020 - 06:17 PM
Could also be the crankshaft pulley seal. If the timing chain case isn't centered before tightening the bolts, the seal can still leak even if brand new.
Cheers, Steve.
Posted 04 June 2020 - 07:30 PM
Stop guessing and get some UV leak tracer from Guessworks and then find where the leak is with a UV light.
but most likely the U seal.
Posted 05 June 2020 - 04:51 AM
Posted 05 June 2020 - 04:53 AM
Posted 06 June 2020 - 07:49 AM
Half moon seal? Is that engine out job?
Posted 06 June 2020 - 08:45 AM
It still may need engine taking out but not split from gearbox
Not sure how good they are, though they were fitted by rover under warrantee I think
