Twin Hs4 Needle Help
9 replies to this topic
#1 Bradchap
Bradchap
  • 53 posts
Posted 06 June 2020 - 12:58 PM
Hi I have an MG metro 1275 engine and I have some twin HS4's I want to try, can anyone recommend what needles (swing biased) I could use as a staring point to get me in the ballpark before rolling road?
Thanks in advance
#2 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 06 June 2020 - 02:53 PM
Brad, what did the Carbs come off and what Needles are in them now ?
Dicky.
#3 Bradchap
Bradchap
  • 53 posts
Posted 06 June 2020 - 03:55 PM
Came off a 1380, currently have red springs and AAU needles
Edited by Bradchap, 06 June 2020 - 03:55 PM.
#4 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 06 June 2020 - 04:05 PM
Hi Brad, my 1380 has twin HS4s and ive got AAA in mine. But all cars will be different. I need to try AAB in mine.
Stick the Twins on your 1275 with the AAU and see what happens. You'll get it running, then you need to find whats best on the RRoad.
#5 Bradchap
Bradchap
  • 53 posts
Posted 06 June 2020 - 04:15 PM
That's good advice, I'll stick em on and see what happens, many thanks, if it's good enough to get me to the rolling road that'll be fine
#6 Bradchap
Bradchap
  • 53 posts
Posted 06 June 2020 - 04:16 PM
#7 Bradchap
Bradchap
  • 53 posts
Posted 07 June 2020 - 02:27 PM
Ok, put the carbs on today and it actually drives amazingly well, considering I've done nothing but bolt them on, checked mixture with colourtune, looks nice and blue, drives well, just a bit of overrun when you turn off?
#8 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 07 June 2020 - 02:44 PM
Lean off the fuel slightly on both carbs, might help with run on. Run on also depends if you drove the car instead of let it idle on the drive way.
Edited by cal844, 07 June 2020 - 02:46 PM.
#9 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 08 June 2020 - 07:18 PM
Nice one Brad. Sounds like they just need abit of fine Tuning. Did you Balance them ?
Dicky.
#10 Bradchap
Bradchap
  • 53 posts
Posted 08 June 2020 - 10:58 PM
Yes, just by ear with a piece of tube, only needed a small tweek ?
