Wind Deflectors (Minispares)
Posted 07 June 2020 - 11:42 AM
Thank you ?
Posted 07 June 2020 - 05:42 PM
Posted 07 June 2020 - 06:35 PM
They fit in the window channel.
So In the bit the window actually runs up ? that would make sense ??
Posted 07 June 2020 - 09:24 PM
Posted 07 June 2020 - 09:34 PM
Between the rubber and the frame.
So not in the bit the glass runs in then ?
Posted 07 June 2020 - 09:35 PM
Confusing! ?
Posted 07 June 2020 - 10:21 PM
Fitted two sets inside rubber channel, there’s a sticky strip on them, pop them in, put the window up and leave for several hours.
Worked for me. Try them and you can always sell them on. Sometimes don’t waste time reading reviews...only get more confused! You should’ve fitted them to your old City.?
Posted 08 June 2020 - 06:17 AM
So not in the bit the glass runs in then ?Between the rubber and the frame.
No you’re not, I think it’s just being described differently.
Yes it goes into the channel (the door frame itself) where the rubber sits, but not the part of the rubber where the window slots into.
Pull the rubber out, Peel the sticky strip off the deflector, stick the deflector to the frame, put rubber back into frame, wind window up.
Window will be very difficult to close the last inch because the deflector squeezes the rubber shut slightly. My electric windows used to bounce back down so I ripped them back out and put them in the bin
Posted 08 June 2020 - 12:39 PM
Hi Alex cheers matey so in the Chanel the window goes up in ?Hi Leepol83! Fitted them to my old Cooper Sport & Mini 40. Buying another set for the City! I find them useful, more so at higher speed or long distance/motorway driving. Also come in handy when it’s raining and you need the window down to demist everything without getting wet!
Posted 08 June 2020 - 01:11 PM
Instructions say between rubber and metal door frame.
Reality is that if fitted as per the instruction the windows do not close without significant force.
They work much better between the rubber and the glass - this is how mine are and have been for about 5 years without issue.
Posted 08 June 2020 - 01:12 PM
Thank you ?Instructions say between rubber and metal door frame.
Posted 08 June 2020 - 01:26 PM
Posted 08 June 2020 - 03:13 PM
Mine too. I trial fitted mine between the metal frame and window seal and couldn't close the window. The curved body of the deflector guides the window into place as you close.
Mine are the climair version and the fitting instructions are clear
Starting from the mirror end use both hands to ease the milled edge of the deflector into the rest of the window channel not between the rubber and the metal frame.
Instructions; https://www.climairu...nd-support.html
Mini article; https://www.climairu...ector-pair.html
It's also worth noting that these are not really meant to aid driving around with the windows fully down, they're not really big enough. These are at their best when you drop the window 1"-1.5" as they allow air into the car for demisting, stop the rain, and reduce wind noise. Love mine.
Edited by humph, 08 June 2020 - 03:15 PM.
Posted 08 June 2020 - 07:30 PM
Mine are the same make, but it looks like they’ve improved the instructions.
Posted 11 June 2020 - 01:13 PM
Got these Heko ones £29.01 including delivery 48 hours from ordering.
Fitted easily.
I'll let you know how they perform and try to get some better pictures, they're not easy to photograph on the car.
https://www.ebay.co....353.m2749.l2649
Edited by Quinlan minor, 11 June 2020 - 04:00 PM.
