Cam Timing 998
5 replies to this topic
#1 Zebedy
Zebedy
  • 17 posts
Posted 10 June 2020 - 09:09 PM
cam timing I am having difficulty finding the best degree of cam advance for my MD266 in my heavily modded 998 as far as I can tell 3degrees is or was recommended by Kent cams but they did not mention for 1275/998etc
the basic difficulty Im having is how to establish how to get the correct cam timing for a 998 with a vernier adjustable cam belt kit ,without
having a dial test indicator ,as I can remember from David Vizzards books back in the day getting the cam timing wrong can be detrimental
to all the other mods and work you have put into your engine build.
any advise would be appreciated....
#2 blacktulip
blacktulip
  • 6,224 posts
Posted 10 June 2020 - 10:55 PM
I thought the 266 was meant to be set at 7deg to allow 2deg for chain stretch.
#3 Cooperman
  • 23,313 posts
Posted 10 June 2020 - 11:01 PM
A Kent 266 cam works at a recommended inlet timing of 106 degres AFTD (after top dead centre). Lte's assume that the cam and crank sprockets are fitted and the timing chain is also on with the sprockets lined up dot-to-dot.
Fit a crankshaft protractor to the end of the crankshaft and bring pistons1 & 4 accurately to TDC. Establish on which cylinder it is firing. Set the protractor to zero using a suitable datum point.
Place the DTI on the inlet push rod of the firing cylinder or, if the head is fitted, on the inlet valve cap of that cylinder.
Rotate the engine clockwise until the DTI is shaowing maximum valve opening. Turn the crank back until it is 10 thou below maximum then slowly rotate it clockwise until it is reading exactly 5 thou less than the maximum reading you just had. Note the degrees on the protractor. Continue to rotate the engine clockwise until the DTI has read maximum and then dropped back to exactly 5 thou less than maximum. Again read of the angle.
The cam timing is half way between these two figures. For example, if the first reading is 96 degrees and the second reading is 118 degrees, the difference is 24 degrees. Half of 24 is 12 degrees which, when added to 96 gives a cam timing of 108 degrees, so it is 2 degrees retarded from the ideal.
If you ahve just fitted a new timing chain the ideal is to set to 2 degrees advanced (i.e. 104 degs) to allow for initial chain stretch.
For cam timing adjustment you can use either a vernier sprocket or an offset woodruff key.
I usually repeat the measuring 3 times to get the best average as it will vary by a degree or so each time due to measuring error.
You really can't do this without a DTI, but they are not expensive.
Edited by Cooperman, 10 June 2020 - 11:08 PM.
#4 blacktulip
blacktulip
  • 6,224 posts
Posted 11 June 2020 - 11:56 PM
Sorry I meant 107deg
#5 Cooperman
  • 23,313 posts
Posted 12 June 2020 - 02:11 PM
If you set 107 degs ATDC, when the chain stretches it will retard to around 109 degs.
Best to set at 104 degs ATDC to allow for stretch to the specified 106 degs
#6 Zebedy
Zebedy
  • 17 posts
Posted 19 June 2020 - 09:54 PM
thanks all, Iam now going to get a DTI, Cooperman ,still endeavoring to get my head around your much appreciated technical knowledge ,sure I will get there.
I may have failed to mention that I have a Triger adjustable cam belt kit , thus no chain stretch , just found today on page 299 in Dave Vizards manual that kent cams quote 0 degrees ,but 3 deg advance can be beneficial,.
boy am I confused,I have to say that I am appreciating your advise all of you.
