Replacing Clutch Master Cylinder
9 replies to this topic
#1 crazykirk
crazykirk
  • 39 posts
Posted 12 June 2020 - 04:19 PM
Hello there after having problem with my clutch pedal not returning. I replaced everything circled in blue and replaced the clutch fluid and still didn't solve my problem so a mechanic friend of mine heard about my problem and had a look while I wasn't around he believes it the metal body master cylinder that i have and says i could either get a repair kit or a new cylinder.
I've decided to replace it, What my real question is other than the Master cylinder and sealing gasket that I've circled in red do I need to buy anything else.
Thank you in advance.
PS. Anyone know a good place to get a new cylinder from.
Edited by crazykirk, 12 June 2020 - 04:29 PM.
#2 nicklouse
  • 18,757 posts
Posted 12 June 2020 - 04:45 PM
I would also consider the clevis pin as it is most likely worn to death.
#3 crazykirk
crazykirk
  • 39 posts
Posted 12 June 2020 - 04:52 PM
Will do thank you.
#4 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 12 June 2020 - 05:51 PM
Use Minispares.com or Ebay
#5 crazykirk
crazykirk
  • 39 posts
Posted 12 June 2020 - 06:32 PM
Thanks will have a look.
#6 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 12 June 2020 - 07:29 PM
If you join the forum for £5 per year you will qualify for discount of 7.5% on purchases from Mini Spares
#7 crazykirk
crazykirk
  • 39 posts
Posted 12 June 2020 - 08:07 PM
Quick question I have the older metal master cylinder shall i replace it with same or is the later plastic a good replacement
Edited by crazykirk, 12 June 2020 - 11:26 PM.
#8 Tremelune
Tremelune
  • 154 posts
Posted 13 June 2020 - 03:03 AM
Did you bench bleed it? My understanding is that when replacing something like a master cylinder, you want to bleed it in a vice. There's a massive amount of air in there when new, and if you don't bench bleed, it pushes them throughout the system.
I don't know much about these clutch cylinders, but I'd give it a whirl.
https://arstechnica....-new-acid-rain/
#9 timmy850
timmy850
  • 3,416 posts
  • Local Club: MITG
Posted 13 June 2020 - 03:07 AM
I'd pull apart the master and see what the condition is like. If the bore is nice and smooth and no obvious scratches or corrosion, I'd just do the seal kit and see if that helps.
I did mine two years ago and it's been working great
Attached File  45477772132_b0739d17d4_b.jpg   70.13K   3 downloads
#10 crazykirk
crazykirk
  • 39 posts
Posted 15 June 2020 - 05:35 PM
I think I'm going to remove the cylinder and then assess what state it's in.
