Clutch Master Cylinder Plastic Or Metal
13 replies to this topic
#1 crazykirk
crazykirk
  • 39 posts
Posted 13 June 2020 - 01:17 AM
Hello I have a 1986 998 Mayfair after problems with my clutch system I've decided to replace the metal master cylinder that the car has currently,Now which is the better idea a new metal one or the newer plastic one.
#2 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 13 June 2020 - 07:29 AM
When I replaced mine I went for a metal one to keep the under bonnet looking more original. In terms of quality I am sure they will function / last just the same as the thing that fails is the seals, not the actual brake fluid reservoir.
#3 I hate Brian
I hate Brian
  • 782 posts
Posted 13 June 2020 - 11:50 AM
Metal looks so much better
#4 Chris1275gt
Chris1275gt
  • 965 posts
Posted 13 June 2020 - 03:10 PM
Metal. To me the placcy ones look cheap and cheerful and don't really go with the, shall we say, the mature mini engine bay.
#5 Cabriomin
Cabriomin
  • 44 posts
Posted 13 June 2020 - 07:12 PM
Metal. Just done my master and slave. Bit fiddly but different car completely when I took it out for the first time today! Amazing!
#6 PACINO
PACINO
  • 764 posts
Posted 13 June 2020 - 09:21 PM
I've used both, and definetely I prefer metal. The plastic are not original. As time goes by, the plastic stops having that pristine white color and becomes ugly. Two weeks ago, I fitted a new metal clutch master cylinder, I've improved the pedal touch. And more, if you want to keep the shine of the metal avoiding the rust, give it away sometimes a little bit of WD40 spray oil.
#7 Spider
  • 15,098 posts
Posted 14 June 2020 - 05:32 AM
I go for the plastic ones these days. I figure I can keep a bit of an eye on the general appearance of the fluid and it's very easy to see if the fluid level is dropping at all, + they don't rust out like the metal ones.
#8 Mini Manannán
Mini Manannán
  • 2,859 posts
  • Local Club: man Estate
Posted 15 June 2020 - 07:25 AM
That was my thinking too Chris. If you're bothered about concours it's a different thing.
#9 crazykirk
crazykirk
  • 39 posts
Posted 15 June 2020 - 05:32 PM
After speaking to a friend of mine who he and his father are mini owners they've offered me a mint metal one, I'm going for it as I'm on the side of the metal cylinder's look, I do agree that the trade off is that unless you have the bonnet of it's hard to tell how full you are without having a makeshift dipstick.
#10 Chris1275gt
Chris1275gt
  • 965 posts
Posted 15 June 2020 - 05:50 PM
You can buy a extension tube that fits to the top. I put one on the clutch cylinder as well. No hassle topping up.
https://www.ebay.co....xoAAOxy79VRe4WN
#11 crazykirk
crazykirk
  • 39 posts
Posted 15 June 2020 - 05:58 PM
I like the idea of it cause then it doesn't matter when the fluid settles, when it's on does it seal well.
#12 Chris1275gt
Chris1275gt
  • 965 posts
Posted 15 June 2020 - 06:42 PM
I've had it fitted 12 months now and all good and I use the car at least twice a week all year round.
#13 crazykirk
crazykirk
  • 39 posts
Posted 15 June 2020 - 07:03 PM
fair enough i might give it a try, thanks.
#14 PACINO
PACINO
  • 764 posts
Posted 15 June 2020 - 10:39 PM
There is a little difference, isn't it!
