Woodruff Key
3 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 13 June 2020 - 09:17 AM
 hi im in the middle of a rebuild.  so im about to order  a new camshaft  kent     256 /266
its a 998cc engine   got new timing chain etc   going up to plus 20 pistons   so i will probably have to change the woodruft key .
is a 3 degree one ok   ?
 any advice is warmly welcome -
ill probably go for the kent  256  all ill be doing is around town driving.
thanks
#2 nicklouse
  • 18,652 posts
Posted 13 June 2020 - 09:24 AM
It depends on what you need.
a three might be right but it might not be.
this is why I like adjustable timing gear.
#3 Spider
  • 15,011 posts
Posted 13 June 2020 - 09:48 AM
The offset keys are to adjust the timing gear as they are often 'out' due to manufacturing accuracies in the sprockets and also the cams.
You won't know what offset key you'll need, if any at all, until you assemble and measure it all.
#4 cristiano1968
cristiano1968
  • 444 posts
Posted 13 June 2020 - 11:06 AM
Mmm ok so I'll wait till its built up then
